This wedghorn is loaded with the Eminence Beta 8 (225w driver) and a 6 bank melded piezo array (2 banks of 3 1016 piezo's)
The standard wedgehorn has the ability to cut through loud stage noise un'eq'd with great results experienced by many on this forum.
If you also provide PA for quiter vocal based acts you probably don't need the cab to cut through, and natural sound of the wedghorn is probably not going to satisfy you, (howevor the build cost and weight still will...)
This EQ curve adjusts the natural honky horn loaded sound of the wedge and makes for a very smooth sounding vocal / acoustic/ keyboard sound, and creates a lot more sibilant clarity when it is required by the acts.
This is especially important if you are using the cabs at acoustic gigs, or quieter jazz gigs. Its important to hear clarity as well as simple volume.
Here is the eq adjustment:-
(I would also pass everything below 100hz to safeguard the driver.)
This EQ is fairly drastic, but will give you a super smooth vocal sound on quiter stages when that is what is required. Its mainly reducing the huge natural peak found in the wedgehorn in the 600hz region.
Knowing that the wedgehorn will sound honky, and a little unusual un eq'd is important as otherwise you may feel a little let down in your new build or think you have done something wrong.
Don't forget, if you are using the monitor to cut through loud stage noise, try adjusting the eq back or turn it off, as this is what many have found works especially well. For my needs I wanted the ability to provide both cutting power and sibilant clarity for quieter acts, and the EQ offers this second option
Dave
