Bassiest songs you've put through your BFM system?
MissileCrisis
Re: Bassiest songs you've put through your BFM system?
#76 Post by MissileCrisis »
For a T39, nothing I've played is more impressive than Tiesto - Chasing summers.
2 x TLAH
1 Titan 39 (lab 12, 15 inch)
1 Tuba 60 (lab 12, 20 inch)
SLA Center
2 x Mini MLTP subwoofers
1 x 212 TH (custom)
2 x Mini-Karlsonators
Owned, but not built
2 x Jack 12 (2512, melded)
sine143
#77 Post by sine143 »
https://soundcloud.com/stholdings/v-i-v ... ids-system
t sixty material ONLY. 4 t48s does not do it.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
MissileCrisis
#78 Post by MissileCrisis »
The new daft punk song Doin' it right has a rather hot bass track. 60% of the bass hits are 50-70 Hz but every third or so is 30-50 recorded ~+6 dB and i'm sure would shake some walls. If you're into chill groovy tunes check it out, great vibes.
2 x TLAH
SLA Center
1 x 212 TH (custom)
MissileCrisis
#79 Post by MissileCrisis »
Heres a list of mainstream (hip-hop) songs in my collection that have exceptionally low bass (all of my reference frequencies are using Glisseq and are the -3db down points of the average/lowest bass hit).
Hey Daddy (Daddy's Home) - Usher 12 hz
In This Thang - Tyga 15 hz
Put On feat. Kanye West - young jeezy 16. Hz
White Girl [Prod. by Drumma Boy] - young jeezy - 16 Hz
Put It Down - T-Pain - 18 Hz
Slow Down(Remix) - clyde carson - 18 Hz
Soul Survivor (ft. Akon) - Young Jeezy - 18 Hz
Dump Truck - E-40 - 19 Hz
Rack City - Tyga - 20 Hz
On My Level (feat. Too $hort) - Wiz Khalifa - 20 Hz
Outta Your Mind - Lil Jon - 21 Hz
Moments - Bei Maejor - 22Hz
Rack City (Victor Niglio Remix) - Tyga - 23 Hz (don't play w/out limiter, it is ridiculously hot on bass)
Poppin Bottles (Feat. Drake) - T.i. - 24 Hz
Poor Man's Hydraulics - E-40 - 24 Hz
One Of Those Nights - Juicy J - 24 Hz
Shawty Say [Featuring Lil Wayne] - David Banner - 25 Hz
Who's Ya Daddy - Juvenile - 27 Hz
Look What I Got - T.i. - 23 Hz (undertone)
Turnin Me On - Keri Hilson - 25 Hz
I have more but anyone who wants to throw a party and has a THT/T60 should give those a try. They'll be on my demo list as soon as I have one/more than one :).
2 x TLAH
SLA Center
1 x 212 TH (custom)
CBIERN
#80 Post by CBIERN »
I mistakenly posted this Tips, Techniques and Supplier Links so here it is where it belongs.
PETER GABRIEL - THE BIG ROOM SESSION 2003
http://bigozine2.com/roio/?p=652
Then my Autotuba began to try to assault me with more low end than I've heard from anything other than test tones.
I had to cut the amp output in half! I used to sell high end audio and we used to hunt for disks (this was circa 1979) that had strong low end to show off with. (remember the real canons in the Telarc 1812 Overture recording?)
I've listened to plenty of electronica here that may do the same but I'm an old guy and it's pretty repetitive so I get bored. This is Peter Gabriel and I've not heard a rock recording with more bass. I'd imagine that they either doubled Tony Levin's bass lines with synth bass or he's using a sub-harmonic synthesizer. There certainly wasn't this kind of bass at his recent So concert.
You see if I'm right or not. Try "Shock the Monkey" but turn the bottom down to stat with. I think the low end is just off the hook.
Another benefit of the BigO site is that all the tracks are downloadable.
Charlie
2X Tuba 24 HL10c
2X Omni 12
2X DR 250
Omni 10
6X Wedgehorn 6
2X Jack 10
doncolga
#81 Post by doncolga »
I haven't read all this thread, but K Wang was requested at a wedding reception last weekend...it was very impressive with two 18" T30's.
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
bassmonster
#82 Post by bassmonster »
Juicy J- I'm Ballin' got that low booty bass.
#83 Post by Radian »
MissileCrisis
#84 Post by MissileCrisis »
TimpBizkit wrote:Missilecrisis, Whiz Khalifa - On My Level is only 31Hz lowest bassline unless there's some infrasonic rumble on there somewhere.
20 Hz sounds like a lorry shaking the building or that sound you get when you open a car window at speed.
I have a pair of MFW-15's, I know what 20 Hz is... If you don't believe me trust this spectrum I just took of it... I clearly stated my criteria of -3 dB as the cutoff for basslines and this spectrum shows 18 Hz.
2 x TLAH
SLA Center
1 x 212 TH (custom)
#85 Post by Radian »
MissileCrisis wrote:I have a pair of MFW-15's, I know what 20 Hz is... If you don't believe me trust this spectrum I just took of it... I clearly stated my criteria of -3 dB as the cutoff for basslines and this spectrum shows 18 Hz.
Keep it level guys. This is niether a thread to point out discrepancies, nor is it a playlist posting board.
Stick to linking to material you've actually put through your own BF gear and feel others might find noteworthy.
If the two of you want to enter into discussion about the technical merit of a particular recording, start a new thread.
Phil1
#86 Post by Phil1 »
CLO
#87 Post by CLO »
:shock:
Just read through this whole thread. I can't believe there has been no mention of DJ Magic Mike.
Feel the bass
http://www.youtube.com/watch?v=8ImWaOLR ... ata_player
Lower the dynamite
http://www.youtube.com/watch?v=Bi_q77GO ... ata_player
And there's so much more..
THTLP x 2
#88 Post by Radian »
sine143
#89 Post by sine143 »
Obligatory Badman VIP post. Check dem sweeps down to 20.
1x bastard XF208
bassmonster
#90 Post by bassmonster »
Some pretty good sweeps here:
