Line drawing
ondasticks
Line drawing
On a titan 48 I'm a bit confused on drawing the 1/2 inch lines . Do I draw them to the right of the original lines which don't alter the original measurements or are they drawn to the left of the original line which means a more narrow mouth?
Re: Line drawing
I can't reply with specific dimensions. But, use Sketch-up and the panel placement drawing to figure out where each panel goes. The lines you are drawing on the sides are for assembly reference, like where to put the panel. Sorry if this sounds obvious. Re-read the plans a few more times, building each step in your mind until everything falls into place.
ondasticks
Re: Line drawing
Never mind the answer was there for me on the precut pieces I have according to plans it says on the outside and based on my panel sizes it checked out thanks bro for trying to help
