OK I am just being cheap here but do I have to use the DBX rta mic or is it just a standard rta mic and any credible one can be used. I do have an old peavey rta mic laying around and I can get a DBX M2 that is included with the px version for a little under $30. I was thinking even if they are a proprietary response curve that the m2 should be the same as the original.
Any input would be appreciated.
will any rta mic work with drpa
- BrentEvans
Re: well any rta mic work with drpa
Any mic will work well enough. You should always tweak it by ear afterwards anyway.
Re: will any rta mic work with drpa
I thought they where just flat mics but good to hear it from someone else.
To be honest I have always worked by ear but find I'm not nearly as accurate as I used to be. With age comes a crutch in the form of auto EQ to start from. This getting old stuff wouldn't be so bad if I had learned to go lighter and more efficient and actually used some of the shortcuts I had available BEFORE I needed to.
Wow I should really proofread my subject titles. Fixed now
- BrentEvans
They aren't all perfectly flat, for sure... but mostly so. There's as much variance between different models as there is between multiple units of the same model.bmf wrote:I thought they where just flat mics but good to hear it from someone else.
I used my behringer ECM 8000 on my PA+ with good results. As mentioned the majority of the cheap measurement mics are reasonably flat that you can get a good base line with them, but wouldn't use them for critical applications.
