miked wrote:Whatever happened with your OTops, Subz?  Did you seal the holes?
I just started my build and have screwed up already, myself. (see my build thread for details). One interesting note: In the pic above this post, right where your four bolts are that hold your bottom-mount top hat, is where I plan on bringing my normal tophat right through the bottom.  That's where the COG is on the cab with the incredibly heavy for their size Delta Pros. It just might fit without a spacer.  Will be interesting to say the least.
Hope your OTops turned out OK.
Wow I haven't been on in ages. I also haven't had much going on in terms of gigs, but its heating up this summer, so I have got back into the swing of things.
I didn't catch this thread, but started to snoop around again after my previous question awhile back about my Otops sounding midbass heavy, so I figured something must not be right. Luckily with my new DRPA+ I was able to EQ them flat outdoors so they sounded alot better on my last gig this past weekend, but I will be opening them up to fix that slot issue.
Now I also bought another set of Otop 12 for cheap, basically just to use the 2512 driver inside, so I will have to look and see if that chamber is needed or not when I swap over drivers.
