I set myself the task with these parameters,
1) Apart from fan and transformer - all out of scrap
2) Build within 4 hours
Luckily I work in air filtration and our company also makes expanded metal.
Here's the w/s laptop set inside its case. The EBM Papst centrifugal fan is mounted on the lid inside the filter surround taking air from the cavity underneath the filter media support ( via the metex ). The cable slots are not covered up - they allow the pressurised air to escape outwards, preventing dust getting in.
Here's the fan whirring away
I close the lid after computer start-up and place the screen over the filter inlet, sitting on two ply rails. The filter media is the type they use in automotive spray boths ( grade M5 or MERV 14 ) that prevent any dust vibrating down through the media. There is metex on the top of the media and underneath ( which you cannot see ) leaving about a 38mm cavity underneath. The lid has a 32mm hole for the fan inlet
Wosrkshop shot.
