XTI 1000 problem!!!!
Chris Betancourt
I have a xti1000 and it keeps shutting down. I have to disconnect the power cord from the back and connect it back again so it would be able turn back on again.
Would a Louisville Slugger fix the problem????
Christopher Betancourt
Authorized Builder
Puerto Rico
All running w/SAC or DL1606
On the table:
too much work!! LOL
Future:
Authorized Builder
Puerto Rico
On the table:
too much work!! LOL
Future:
Gregory East
Re: XTI 1000 problem!!!!
Or a flight from the 10th floor.
It might be possible to hook up Bandmanager and look for an update of the firmware.
There have been some problems with early versions of the Xti amps and a flat ribbon cable connector (to the front panel IIRC). Look up your amp serial nr and search the web for that issue. There is a reference somewhere on which serial nrs can be affected by this. After that, you could also do a firmware update as Gregory suggests, but I'm not sure that would fix an issue like this that suddenly pops up. It doesn't sound like a firmware issue to me.
Edit: do any warning lights come on when it shuts down, or does it power off completely without any warning or indication?
Chris Betancourt
No, it just turns it's self off all alone like if the power switch is pushed off. If there's a link to that serial # I'll check and see if anyone knows one shoot it out.
Thanks Guys.
Thanks Guys.
Authorized Builder
Puerto Rico
On the table:
too much work!! LOL
Future:
Authorized Builder
Puerto Rico
On the table:
too much work!! LOL
Future:
Another xti problem thread? I'm staying away from these amps.
That's the problem with some of this gear. If there isn't a reasonable level of reliability, it's of little value for live production work. When it is working, the guy who wants to make lots of noise in the backyard may find it useful.
T48s
WH8s
SX212
T48s
WH8s
SX212
C'mon guys quit bashing already...I have four crown xti series...NEVER a problem in years.
I would call crown they are bound to help you troubleshoot it and isolate the issue. You can also try the crown forums.
http://www.crownaudio.com/forums/
One reason you may hear about some problems is that so many people have 'em.
I had one Crown XLS DOA (when they first came out), but it was promptly replaced and the other three Crowns I've had haven't had a hiccup.
Same here, I only have one but it is problem free. There are a lot of these amps out there, not surprised every now and then there's one with a problem. The ribbon cable issue was only with an early production run and to the best of my knowledge it was quickly solved.netwerks wrote:C'mon guys quit bashing already...I have four crown xti series...NEVER a problem in years.
I have 2. The only problems I have had was bad power from the venues. 3 years service and still bumpin.AntonZ wrote:Same here, I only have one but it is problem free. There are a lot of these amps out there, not surprised every now and then there's one with a problem. The ribbon cable issue was only with an early production run and to the best of my knowledge it was quickly solved.netwerks wrote:C'mon guys quit bashing already...I have four crown xti series...NEVER a problem in years.
4 20" T39(built)
2 WH8(built)
3 WH10(own)
4 DR200(own)
1 Jack 12(built)
SAC 24 Channel Mixer
SAW STUDIO Recording
We have 11 XTIs in the shop, a handful installed in various venues as well. None of our amps have suffered any failures, one amp that we have installed in a venue is at Crown as we speak. I can't help but laugh at the "gotta stay away from that brand" comments.
wallywally
The 2 amps that I own and had to repair the ribbon cables were not in the problem range of serial #.
I doubt the problem you are having is related to ribbon cables, the power switch is mounted directly to the main board IIRC.
Builds:
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
Same here, I have 3 Xti's, and 3 years, all running strong.AntonZ wrote:netwerks wrote:C'mon guys quit bashing already...I have four crown xti series...NEVER a problem in years.
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
Chris Betancourt
What kind of problem did they give you did they turn off by its self, I'll be opening mine today to see the inside.wallywally wrote:The 2 amps that I own and had to repair the ribbon cables were not in the problem range of serial #.
Authorized Builder
Puerto Rico
On the table:
too much work!! LOL
Future:
Authorized Builder
Puerto Rico
On the table:
too much work!! LOL
Future:
wallywally
http://www.billfitzmaurice.info/forum/v ... =6&t=18515Chris Betancourt wrote: What kind of problem did they give you did they turn off by its self, I'll be opening mine today to see the inside.
Builds:
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
