Dec 26th - sand, spray
Dec 27th - finally fed up with trying to spray at 40°F, and cleaned up a corner of the shop, cranked up the heat to 65°F and sprayed them again. First side or two, I got the weird wavey sort of sag that I associated with having to thin my lacquer too much and it just would not hold on a vertical surface. So I blew out my material hose, added just a little more straight lacquer to thicken it up and ended up with orange peal.
My son saw this smiley and asked why the guy was hitting the horse in the balls.
After 4 days of failure in the spray room, we were beginning to relate the feeling of bashed like that horse.
Dec 28th - looked over my rig after sanding out the mistakes of the day before. I found that the knob that adjusts the amount of pressure into the pot had moved. I never touch this knob and it had been cranked way up so that I probably had triple the pressure that I normally have pushing the material out the hose. It was a miracle I got anything close to reasonable with that setup.
Readjusted my pressure and finally put on a nice coat.
 (me)
  (my son)
Waited overnight and into the afternoon to let the finish set up a little. Came up with a good distraction for a young lad that has seen his Christmas present get delay after delay - loaded up the 4-wheelers and headed up the hill to find some snow to drive them around in. Great time but cut short when the transmission went out on one and we had to use the other one to tow it back to the trailer.
But a short day in the snow meant we came back a bit earlier to bring the speakers home!
Now it was time to assemble.
First was putting some gasket tape on the input cups.
