20" Wide, T39, 3012LF, Cut bottom for wheels, 9mm ( 3/8" ) Italian Poplar construction, 3 1/8" internal braces except for mouth. 1 hand-hold in bottom panel - 1 hand hold at back of top/top of back.
Here are the shots from a previous post;
Here're the finished articles;
Super light and going through their sound check tomorrow.
One thing I will never do again, even if the customer demands it, and that's cut the bottom back to fit wheels. In fact even leaving the back straight and putting inset wheels in - no no no no.
They rattle like buggery and the time taken to cut, trim, fit, line up, make sure everything is even - forget it, I am just past them. I'll buy the customer a collapsible hand truck instead.
These things are so light, they are an easy pick-up anyhow.
I learned that the thin Poplar needs a lot of control when assembling I ended up with one slightly curved top ( out by 4mm - gnat's tit over 1/8" ) on one and a curved bottom ( 3mm out ) on the other. I know what to do next time - use straight bars and clamp at each step which will fix that 100%
Other than that I am a happy camper so far.
If you need more pics, pay me!
The proof of the pudding is tomorrow, so long as the weather holds out.
