Omni 15 Tallboy - my first build
Michael Ewald Hansen
Re: Omni 15 Tallboy - my first build
#46 Post by Michael Ewald Hansen »
Bill Fitzmaurice wrote:
Michael Ewald Hansen wrote: You should have one of the coils standing up to avoid cross-talk :)
Crosstalk can be a problem when the LP/BP/HP filters are on the same board. When mounted on separate boards the coils are too far apart for it to be a concern.
I wouldnt have mentioned it either if it wasn't because he has 2 coils on the same board, lying down in the same plane :)
Authorized Builder - Denmark
#47 Post by Bill Fitzmaurice »
Both are part of the midrange BP, so it's no concern. If you had an LP pass through close to a BP pass through that could be a problem.
Rickyvt
#48 Post by Rickyvt »
So I guess I can leave it as it is if I don't put the filter boards next to each other?
#49 Post by Tom Smit »
yes.
Rickyvt
#50 Post by Rickyvt »
Quickly finished the high pass filter, but I won't be doing anything for a while since I'm on vacation right now :hyper:
Greetings from Rome!
Rickyvt
#51 Post by Rickyvt »
Kids to school again, me back to work again, it took a while to get back at it...
made and installed the braces and flanges, and put on wheels and a handle...
BTW I wasn't able to install the woofer because the tall vertical brace from bottom to mid horn was in the way. It was build according to the plans, and I did not check with the woofer installed. I'll be making an adapted brace but for now I removed a part to get the woofer installed :(
Attached the back panel and impressed every listener :D
Stll need to do the accoustic foam, but I noticed a problem with the mid horn. In my opinion the driver is hitting the phase plug. I hardly notice it when playing recorded music, but with bass it's really annoying because I can hear it at any reasonable sound level...
Still deciding on the color. I would prefer to not use black. Does anyone have any experience with Tuff Cab paint? I might go for white
OmniTB1 (1).jpg (21.69 KiB) Viewed 3771 times
Rickyvt
#52 Post by Rickyvt »
#53 Post by LelandCrooks »
Nicely done.
Bas Gooiker
#54 Post by Bas Gooiker »
Wow, that is one sexy looking last picture. The bass and the cab together on that checkerd floor. :clap: :clap: :clap:
I dont know how flowless the sides are but i'd stain the front to mach the bass.
If i remember correctly Tuff Cab is what most of the Aussies use, you should be ok with that.
#55 Post by AntonZ »
Tuff Cab is made by Aldcroft Adhesives in the UK. Not sure if it is available in continental Europe. I have used Warnex, very nice looking finish with a standard textured roller. It can be purchased from Thomann:
1kg €25 http://www.thomann.de/be/warnex_strukturlack_1kg.htm
12kg €268 http://www.thomann.de/be/warnex_strukturlack_12kg.htm
Not sure if it is as durable/better/worse compared to Tuff Cab, Duratex and others.
Rickyvt
#56 Post by Rickyvt »
I know Warnex but I only found black paint and I would prefer something else... I can order Tuff cab from the website above
#57 Post by AntonZ »
Yeah, I wish we had Duratex in Europe. Black is quite boring but it was the only affordable product I could find back when I needed some. Blue Aran have several colors in stock. In addition, Aldcroft can make just about any color you like, although a custom color will cost you some. You can email or call them, they are nice and helpful people.
Rickyvt
#58 Post by Rickyvt »
Thanks AntonZ, I'll keep that in mind!
Bas Gooiker
#59 Post by Bas Gooiker »
Warnex 6kg can costs 87,50 at bax-shop.nl but again only in black.
http://www.bax-shop.nl/overige-material ... tails.html
Rickyvt
#60 Post by Rickyvt »
Bas Gooiker wrote:Wow, that is one sexy looking last picture. The bass and the cab together on that checkerd floor. :clap: :clap: :clap:
The problem here is that I have some sunken screws hidden with filler. You remind me of my wife, she said just the same about staining it to match the bass :D
But I don't know if I'm gonna keep this bass as long as the Omni TB...
Maybe I will paint the front black and the sides white. It would match the checkered floor :lol:
The Tuff Cab technical data says not to paint over anything containing cellulose solvents like filler, primers... I've used the two component type filler with hardener 1:50. It doesn't state anywhere that it contains solvents. Would it be safe to use Tuff Cab then?
