Installing/Attaching expanded metal grille
dheafey
#1 Post by dheafey »
Hello all,
I'm approaching the end of the construction phase of my O12 build and am looking for some tips on how to best install an expanded metal grille. Per the plans, I've installed the standoffs for a full metal grille and will be using something similar to this:
Keeping it simple, I was thinking weather stripping on the standoffs to prevent rattling, lay the extended metal on top then screw it down with 3/4" anodized screws, a neoprene washer between the grille and screw head.
:feedback:
T39 - Dual BP102 23"
AutoTuba
J12 x 2 - Deltalite 2512
O12 - Dual BP102
Re: Installing/Attaching expanded metal grille
#2 Post by Grant Bunter »
Sounds good!
I do believe Leland sells screws that have attachable caps which might look a bit tidier...
#3 Post by LelandCrooks »
Yep, use any #6 or #8 round head screw.
http://www.speakerhardware.com/screw-cover-8-10.php
dheafey
#4 Post by dheafey »
LelandCrooks wrote:Yep, use any #6 or #8 round head screw.
Shweet!! :P I will be placing an order shortly.
AutoTuba
O12 - Dual BP102
