T18 Build
bcdaffin
T18 Build
#1 Post by bcdaffin »
I've been going back and forth all summer about whether or not I should build a sub. Didn't decide YES right away due to budget and the fact that I already have a 10 inch ported sub. Found this site while browsing the Parts Express techtalk forum. After reading around a bit and adding up the estimated cost, I decided I had to make one.
Due to size restraints (a.k.a. tiny ass dorm room), I decided to go with a Tuba 18. I guess I could have went with a different design long style and kept it under my bed.. but I already bought plans and ordered some parts. Plus that would have been a PITA to get up 4 flights of stairs.
I read through the plans as soon as I got them last night, and again today. Tomorrow I get to hunt around for suitable plywood, but won't actually get to make some sawdust until friday. O well. I was just too excited and had to start my build thread now haha.
-Brian Daffin
shawn_g
Re: T18 Build
#2 Post by shawn_g »
The T18 is a fun build and goes pretty quick once you get past the initial steps.
I'll bet I know what you're going to power it with. :wink:
Good luck!
Re: T18 Build
#3 Post by Tom Smit »
The T18 will give you a lot of clean bass. :D
bcdaffin
Re: T18 Build
#4 Post by bcdaffin »
Just curious, anyone know how heavy a T18 would be if made of mdf? I only have to move it up 4 flights of stairs twice a year.. wouldn't be too bad
-Brian Daffin
SirNickity
Re: T18 Build
#5 Post by SirNickity »
Ugh. Not too bad if you're used to car audio subs I guess. After building some plywood subs, my first tapped horn I built with MDF is a lead weight. It's a good thing it rarely moves.
You can certainly do it if you want, but no one that uses Baltic Birch goes back to MDF.
bcdaffin
Re: T18 Build
#6 Post by bcdaffin »
So when I woke up this morning, I checked the weather and saw there was rain from noon til about 4 or 5. Since I have to do all my cutting in our driveway, my dad definitely won't let me do it in the garage, I decided I would just draw the lines. 1 o'clock rolls around, a bit cloudy, but no rain. I check the weather again, it's now a 10% chance for the rest of the day :x I start to bust out the power tools and make some sawdust, less than an hour later... it starts sprinkling and I have to rush everything back inside :bash: that pretty accurately describes how I feel about weather.com right now :wall:
-Brian Daffin
bigjohn1
Re: T18 Build
#7 Post by bigjohn1 »
I would have to agree with above MDF is heavy and other bad things hate that stuff not sure what its good for. Baltic birch is really nice to work with I must say
I have been working on a dual tub18 will need some handles for sure and it is a little heavy but from what I have heard from it so far with only a 20watt amp hooked to it not bad at all will see how it sounds with a bigger power supplied to it soon.
Need a way to make my pic smaller in size.
dheafey
Re: T18 Build
#8 Post by dheafey »
bcdaffin wrote:Just curious, anyone know how heavy a T18 would be if made of mdf? I only have to move it up 4 flights of stairs twice a year.. wouldn't be too bad
It might not be that bad weight wise, but cutting the stuff is nasty; the dust is bad news. Even outdoors I'd suggest a decent mask, not one of those cheap paper ones. Google "breathing mdf dust" for some eye opening info.
T39 - Dual BP102 23"
AutoTuba
J12 x 2 - Deltalite 2512
O12 - Dual BP102
bcdaffin
Re: T18 Build
#9 Post by bcdaffin »
As I was putting the last side on my tuba today, I realized I hadn't taken a single picture yet... ooops :| So I took a few then, enjoy.
p.s. is 180lbs of plate weights enough??
-Brian Daffin
Re: T18 Build
#10 Post by Tom Smit »
Yah, I think 180 lbs is enough! :lol: Good build so far. Let us know in the reviews how it sounds.
shawn_g
Re: T18 Build
#11 Post by shawn_g »
Looks good. How does it sound?
bcdaffin
Re: T18 Build
#12 Post by bcdaffin »
Not sure yet, The glue has only been curing for 12 or so hours. I'm going to wait a bit longer before I test it out. And then its go time :D But the real test run is this weekend when my parents are out of town :twisted:
-Brian Daffin
bcdaffin
Re: T18 Build
#13 Post by bcdaffin »
I LOVE IT :hyper: I'd just like to take a minute to thank Bill, seriously, you rock man.
EDIT: shoulda trimmed the gasket tape around the access panel before posting a pic... o well, its trimmed now
another edit: theres a couple leaks around the access panel that I need to fix, damn
a shot of my old sub chillin on top of my T18. That 8inch dayton murders my 10inch sony.
-Brian Daffin
SirNickity
Re: T18 Build
#14 Post by SirNickity »
Awww! It's so cuuuttee! *squuueeaall* :P
Ahem. Right then. Good job bro.
shawn_g
Re: T18 Build
#15 Post by shawn_g »
Nice! :clap:
Get the mouth pointed into a corner or at least a wall and it will really come to life.
