New WH8
Re: New WH8
I just added a DEQ2496 to my system
Bill how do u like it ? I have been reading the manual and thinking about getting one.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
Re: New WH8
The DEQ I love. The manual, not so much. I found the FBD instructions almost useless, not telling you that if you don't set the threshold at -40dB the Learn mode won't work.
Re: New WH8
Holy crap, so that's the damn secret.Bill Fitzmaurice wrote:The DEQ I love. The manual, not so much. I found the FBD instructions almost useless, not telling you that if you don't set the threshold at -40dB the Learn mode won't work.
Re: New WH8
If only manuals were written by Art majors instead of geeks they would be like so:LelandCrooks wrote:Holy crap, so that's the damn secret.Bill Fitzmaurice wrote:The DEQ I love. The manual, not so much. I found the FBD instructions almost useless, not telling you that if you don't set the threshold at -40dB the Learn mode won't work.
1. Do this
2. Do this
3. Do this
4. It's done
It took me a good four hours of fiddling about to decipher how to use the DEQ, and I've got 45 years of audio engineering experience to draw on. I pity a newbie trying to deal with it.
Re: New WH8
I'm glad it's not just me that thinks the manual for the DEQ is just complete shit.
Re: New WH8
I wasn't trying to say i have a DEQ 2496,i was trying to Quote Bills statement.That manual is the reason i dont own one now,i think i'm going to keep studying the manual to get a better understanding of it before i buy it,i may just rebuild my T 48's while i study.
2 SLA HT systems
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
- jswingchun
Re: New WH8
I haven't been back here since I posted my question. Busy building cabs and playing a show this weekend. Thanks for the replies. I think I may end up rebuilding mine to the new design sometime. My old ones were the second cabs I ever built, so they were a bit messy.
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Re: New WH8
I can't help but think, "it's an EQ -- how hard could it be?" Famous last words, eh?
- BrentEvans
Re: New WH8
Heh... it's four different EQs... Parametric, graphic, dynamic, and feedback destroyer... and they all operate a bit (or a bunch) differently than all the other ones.SirNickity wrote:I can't help but think, "it's an EQ -- how hard could it be?" Famous last words, eh?
Although, I will say it only took me about 20 minutes to get the hang of it. Then again, I'm a nerd.
Re: New WH8
20 minutes huh,i know whose P.M. box i will be blowing upBrentEvans wrote:Heh... it's four different EQs... Parametric, graphic, dynamic, and feedback destroyer... and they all operate a bit (or a bunch) differently than all the other ones.SirNickity wrote:I can't help but think, "it's an EQ -- how hard could it be?" Famous last words, eh?
2 SLA HT systems
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
Re: New WH8
I had it all wired except the fbd. I never did get that thing to work. But then again, I never had much feedback with the rig. What I had I could pretty quickly notch out.
Re: New WH8
Leland do you still sell DEQ 2496's ?
2 SLA HT systems
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
Re: New WH8
Not used it on mine yet, but IIRC, in the manual, one thing I remember is that at least one adjustment (however minor) on PEQ needs to be made before FBD will work...
Re: New WH8
Not quite. The PEQ and FBD share the same ten filters; you can use them on one or the other, but not both. I don't see much use for the PEQ with the 31 band graphic there, so I assigned all ten filters to the FBD.Grant Bunter wrote:Not used it on mine yet, but IIRC, in the manual, one thing I remember is that at least one adjustment (however minor) on PEQ needs to be made before FBD will work...
Re: New WH8
Funny that I saved so long to complete my rack with the DEQ, but often I actually leave it off. I notice that the DEQ panel gets hot after a long night, and the heat ain't coming from the Crown. If you're just running analog, it might be interesting to know that the signal will continue through it without a glitch when powered on/off. I've used results of the RTA to enter some simple corrective eq into the DCX so things sound great without it. Great to have at the press of a finger though!
I'd still like to learn how to use it more fully, especially effective use of the feedback eliminator.
2 x T30 23" -3012LF v-plate
2 x Econowave Deluxe HO (awesome custom tops using 3012HO and B&C DE250 on QSC horn)
1 x T39 25" -3012LF
1 x Autotuba -Tang Band
"No Toby, I said a PHILLIPS screwdriver..." (Used Cars, 1980)
1 x T39 25" -3012LF
