DR250 stealth grill
Drey Chennells
DR250 stealth grill
#1 Post by Drey Chennells »
http://www.facebook.com/media/set/?set= ... 637&type=1
bfDR250 Stealth Grill_phixr.jpg (91.71 KiB) Viewed 10017 times
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
Re: DR250 stealth grill
#2 Post by Tom Smit »
Looks good! How do you hold the grille in?
Harley
#3 Post by Harley »
Nice! :clap:
N.Webber
#4 Post by N.Webber »
Looks very nice, great idea and implementation. I really like it! :clap:
Authorized Builder
- 6 DR290
- Omni10.5
- AT, TAT
- Tuba 48
- 2 WH10
- Truck Tuba
http://www.boniton.co.il
Drey Chennells
#5 Post by Drey Chennells »
Thank you, that's praise of the highest order gentlemen.
The grill was made to pressure fit in a 1/4" deep groove along the arrays length. That groove was created with a full length 1/8" thick strip glued to the array flange, 1/4" less width than the array flange width. It makes a perfectly tight fit, no hardware.
Copy of DR250 019_phixr.jpg (52.42 KiB) Viewed 9964 times
InfraCoustik
Mark Coward
#6 Post by Mark Coward »
Very nice look - so if I am following your description, the array sort of hangs over 1/8" creating a groove, and the grill has folded edges?
Thanks
Mark Coward
Drey Chennells
#7 Post by Drey Chennells »
Mark Coward wrote: the array sort of hangs over 1/8" creating a groove, and the grill has folded edges?
Thanks
Yes the grill is folded at the edges to fit inside, however to be clear the array flange itself is what has an additional 1/8" thick top to bottom strip glued to it, 1/4 less wide than the flange and that's what creates the groove.
InfraCoustik
Harley
#8 Post by Harley »
Thanks
Perhaps a real close up shot may explain all...
Drey Chennells
#9 Post by Drey Chennells »
I'll see if I have any better than the above construction pic, in it you may be able to spot the groove created by the strip.
InfraCoustik
Mark Coward
#10 Post by Mark Coward »
Drey Chennells wrote:I'll see if I have any better than the above construction pic, in it you may be able to spot the groove created by the strip.
I think I understand now, the groove is the 90º corner, 1/8" x 1/4" ? The grill edges butt into this, is there like a double bend on the edges? Looks like it would pop out otherwise, though the pointy metal cut edge may prevent it.
Mark Coward
Drey Chennells
#11 Post by Drey Chennells »
Mark Coward wrote:I think I understand now, the groove is the 90º corner, 1/8" x 1/4" ? The grill edges butt into this, is there like a double bend on the edges? Looks like it would pop out otherwise, though the pointy metal cut edge may prevent it.
The tension of the curve holds the edges tightly in place. This 8mm hole grill takes a good flat edge off a grinder and no doubled over edge is needed.
InfraCoustik
#12 Post by Tom Smit »
If you "view" the raw-wood picture, then hold the "control" key as you hit the "plus" sign several times, you can see that the sheath is spaced out thus creating a groove. As you look at that, compare it to #8 of 14 Facebook pictures to get the idea.
Harley
#13 Post by Harley »
Tom Smit wrote:If you "view" the raw-wood picture, then hold the "control" key as you hit the "plus" sign several times,.
UnF%^%$^$ingbelievable! Holding CTRL and rotating the middle mouse wheel magnifies and also diminishes. I never knew that.
Drey Chennells
#14 Post by Drey Chennells »
:lol:
InfraCoustik
Greg Plouvier
#15 Post by Greg Plouvier »
Very nice!
Greg Plouvier
