Does the driverack PA+ have everything I need?
Razor
#1 Post by Razor »
Just wanted to ask if the DBX Driverack PA+ actually has all of the processing I could need for a set of BFM cabs?
Michael Ewald Hansen
Re: Does the driverack PA+ have everything I need?
#2 Post by Michael Ewald Hansen »
Razor wrote:Just wanted to ask if the DBX Driverack PA+ actually has all of the processing I could need for a set of BFM cabs?
It does.
Authorized Builder - Denmark
Razor
#3 Post by Razor »
It does.
Thanks. :D
Israel
#4 Post by Israel »
so the PX and it has a mike
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
Razor
#5 Post by Razor »
Israel wrote:so the PX and it has a mike
Isn't the PX for powered speakers?
#6 Post by Bruce Weldy »
I think the only difference is that the PX only handles a 2 way crossover....but with passive crossovers in the BFM tops, that's all you need.
Razor
#7 Post by Razor »
I think the only difference is that the PX only handle a 2 way crossover....but with passive crossovers in the BFM tops, that's all you need.
Well, even better. The PX is cheaper.
#8 Post by Grant Bunter »
Is this for the Church?
You're currently running powered speakers yeah?
Should be fine...
Razor
#9 Post by Razor »
Grant Bunter wrote:Is this for the Church?
Should be fine...
Yeah I knew it would be fine for the powered speakers but my assumption is that when we upgrade our speakers we will be getting passive ones.
#10 Post by Grant Bunter »
I replied about that in your other post.
With a consideration to the centre cluster also :)
Razor
#11 Post by Razor »
Grant Bunter wrote:I replied about that in your other post.
Yeah, thankfully that center speaker won't be coming with us when we move (still have no idea when that will be, hopefully in the next couple of years).
