OTOP 15
Re: OTOP 15
Sweet! TS-90s? Love those stands.
- Chris_Allen
Re: OTOP 15
We've not seen any OmniTop15's built in a while.
How do you like them in comparison to what you've had before?
There used to be (probably is still) a great youtube video with some in.
Re: OTOP 15
Totally destroys the Mackie SA1530Z's we used to use for band practice. The piezo array is a night and day difference compared to the single compression tweet on the mackies (thanks to Leland Crooks)Chris_Allen wrote: How do you like them in comparison to what you've had before?
Im currently building a total of 4 Otops and 4 Tuba 60s 20" wide with lab 12s. Can't wait
Re: OTOP 15
If I can ask... WHY did you build 15's if you're building 4 tuba 60 ?
I guess they can be used without subs, but that must require a fair bit of eq'ing since the lower end is like 10 db less sensitive than the rest...
Without any eq, how do you find the sound ? Does it sound like the bass is too weak to keep up with the super sensitive midrange ?
Built : 2 x beta8 wedgehorn w/melded array
20'' wide t39 3012lf loaded
still can't decide on tops !
Re: OTOP 15
I love when he said "Totally destroys the Mackie SA1530Z's"
, do that was the flagship model before the HDs series came in ?.
Re: OTOP 15
He's comparing it to what they had before. Why does that make youTruckinve wrote:I love when he said "Totally destroys the Mackie SA1530Z's"![]()
Re: OTOP 15
Cause Mackie SA1530Z was not a bad cab, and that review shows how good the Otop is.
Re: OTOP 15
mr.lussier wrote:If I can ask... WHY did you build 15's if you're building 4 tuba 60 ?
Is the bass too weak? For my purposes yes. The tuba 60 is one of the subs that Bill suggests for the Otop 15.
Re: OTOP 15
Can't wait for the review... But watch out, you could probably kill somebody with 4 t60s...
What I meant is if you're building subs anyway the omnitop12 could have served you well and it is smaller and lighter, for a similar output.
Re: OTOP 15
Lol!mr.lussier wrote:But watch out, you could probably kill somebody with 4 t60s...
I like that the otop 15 can do an audience of 50+ more people per pair than the 12s which is great if you are using one pair for a 150-200 crowd.
