Amp to run 36" T48s loaded with 3015lf
Is this amp OK?
SirNickity
Re: Amp to run 36" T48s loaded with 3015lf
#16 Post by SirNickity »
DJPhatman wrote:Spend the extra $$ and get the light-years better dBx Driverack 260 instead.
Curious about this -- why the 260? I have the PA+, and the only thing I can think of that it doesn't do, that I wish it could, is provide additional outputs for secondary systems (fills, other "zones", etc.) It has a "mid" output (for active 3-way) that I don't use, but IIRC, it can't be repurposed as an independent output with its own crossovers. I may be wrong, I need to hit the manual on that one.
Anyway, that's a pretty rare want, and I do have an older analog crossover in my "spare parts" pile for those once in a blue moon gigs.
