Hi!
i have an Omni12 with 2 BP102 (4ohm) and i was looking for a nice bass head...
Will the Mb500 be ok for this cab? Is it too much power? BP102 are ranked at 200w each...
MB500 specs
• 500 watts @ 4 ohms, 350 watts @ 8 ohms
• 10dB pad
• Four-band active EQ w/variable contour
• Effects loop and tuner output with mute
• Headphone/line output
• XLR out, pre/post EQ & ground lift switch
• Boost footswitch
• Two speakon outputs
• 10.75x8.5x1.75
Omni12 +GK MB500 good idea?
Gregory East
Re: Omni12 +GK MB500 good idea?
No harm in trying it out. You should be able to hear the bp102 getting stressed if you push too hard, turn down and don't do that again.
I have the MB500 squared. I use it at home (I don't gig) and love it with my single J112. Makes more noise than I'll ever need. Should be a perfect match with an Omni 12x210.
Does it have a volume control?katu_lp wrote: Will the Mb500 be ok for this cab? Is it too much power?
Thanks man! I was afraid that it would have too much power, i''l give them a try!DJPhatman wrote:I have the MB500 squared. I use it at home (I don't gig) and love it with my single J112. Makes more noise than I'll ever need. Should be a perfect match with an Omni 12x210.
