Nuetrik Powercon help
la80vette
#1 Post by la80vette »
I,m wiring up some a/c cables using neutrik powercon connectors the plug has indicators for ground, N,and L. What are the N and L ? Where do I put the black hot and white nuetral.
Thanks,
Stephen
2 SLA PRO (built by Leland)
2 T39 24" 3012LF (built by Leland)
2 Jack 10's (built by Leland)
4 Wedgehorn 8's (built by Leland)
1 XF210 w/Legend 1028 (built by Leland)
la80vette
Re: Nuetrik Powercon help
#2 Post by la80vette »
Nevermind. L=Live, N=Nuetral
Gregory East
#3 Post by Gregory East »
If you need to ask you should be paying a professional to do it. A/C can draw a heap of current, get it wrong you could have a fire, nevermind the shock hazard.
#4 Post by Bruce Weldy »
If you have to ask - you might just learn something.....oh.....you did, and you did.
Now, go put it together - you'll be fine.
If I hired a "pro" every time I didn't know something, I wouldn't have gotten very far in the DIY world.
la80vette
#5 Post by la80vette »
I've wired plenty stuff before. I just never saw the L and N before. But thank you for your concern. Not looking to hurt anyone. Just enjoy doing these things and continuing to learn.
Stephen
bitSmasher
#6 Post by bitSmasher »
:shock:
Learning, sure... but high voltage AC doesn't really give you a chance to fix your mistakes.
Gregory East
#7 Post by Gregory East »
Yeah, that's really scary not knowing your phase and neutral.
Over here you are allowed to wire things on mains power but it must be overseen and signed off by a licenced electrician.
#8 Post by Tom Smit »
I saw 'L' as ....Load
#9 Post by LelandCrooks »
Tom Smit wrote:I saw 'L' as ....Load
+1
la80vette
#10 Post by la80vette »
I thought it was load too. Asking questions so to be sure. Geesh.
Five9teen
#11 Post by Five9teen »
Actually L stands for Line as in "line voltage"
Your power connections should be:
Black = Line
White = Neutral
Green = Ground
Double check your connections for continuity with an ohm meter before you apply any Line voltage.
Always double, then triple check your connections for proper polarity for your personal safety, first and foremost, and equipment protection.
If you are in the least bit unsure, ask someone who knows.
Electricity is nothing to screw around with. We are not talking about just a blown driver here, just be careful.
Safety first guys. :cop:
2 X Frankensteiner Tops
2 X Frankensteiner Subs
1 X DCS255-4 10" TT
1 X DCS205-4 8" TAT
1 X DCS205-4 8" Dual TAT
Rectangular TLAH
SLA Center
2xSLA Pro 2x6
TUBA 30 Slims on the way
Rune Bivrin
#12 Post by Rune Bivrin »
I'm obviously not completely up to speed on electrical code in US, but it strikes me as a very dangerous practice to make any assumptions about which wire is line and which is neutral.
Here in Sweden, as in most of Europe a regular mains plug can be inserted either straight or reversed. There's nothing on the exterior of either the wall socket or the plug that indicates polarity. Thus, devices are forced to treat BOTH wires as live, which can only be a good thing. The safety ground, however, should always be trusted and observed.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
la80vette
#13 Post by la80vette »
Who's making assumptions. All I did was ask a question. I got my answer from an electrician friend before anyone here responded. I am so sorry I asked the question at all. I've learned my lesson.
Five9teen
#14 Post by Five9teen »
Just trying to help. No criticism intended. Just want everyone to be safe. :cowboy:
1 X DCS255-4 10" TT
1 X DCS205-4 8" TAT
Rectangular TLAH
SLA Center
2xSLA Pro 2x6
la80vette
#15 Post by la80vette »
None taken Five9teen. You're response is exactly what I was hoping to get. Thank you very,very much.
