Yup, you get the same result by paralleling 2 cabs as paralleling 2 drivers in 1 cab2Channon wrote:would it be the same if I were to wire two single loaded cabs parallel?
@Bassmonster - good to hear you are making progress! I use a wood filler puttybrand called "PolyFilla" - its perfect for cabs as its very easy to work with, dries very fast and 1 layer of duratex completely covers it up.. The specific version of Polyfilla i use is called "Træflex" don't know if something similar can be found in the US, but its cheap here and very nice..
http://www.traelasten.dk/ImageRoot/Imag ... 0_zoom.jpg
There is also a company called Henkel(loctite in the US - makes PL) which has a product called Plastic Padding (Chemical Wood) which is quite easy to work with and pretty much as strong as wood itself..
Can't wait to hear your reaction on using Duratex on your cab - it amazed me completely the first time i used it
