THT-LP (26" wide)
tomsza
Re: THT-LP (26" wide)
#31 Post by tomsza »
fitzwaddle wrote:
tomsza wrote:I bought the Bash plate amp for this thing and I'm thinking of adding a plywood panel to put in front of panel #10 and mounting the amp to that. Is there anything wrong with doing this? Like vibration damage?
You mean mount the amp in that long / sealed triangle next to the mouth (between 9, 10 and the side)?
Here is where I was thinking. Excuse the crude illustration and incorrect scale.
fitzwaddle
#32 Post by fitzwaddle »
Seems like it would work - but of course you'd need to work out a path to run the wiring from the amp to the driver chamber, and seal off those holes - not sure if that's OK or not. Seems like the amp would be OK since its a sealed off part of the cabinet - assuming its deep enough.
Caveat: I'm just speculating, Bill or one of the builders feel free to tell me I'm full of it.
#33 Post by Tom Smit »
tomsza wrote: Here is where I was thinking. Excuse the crude illustration and incorrect scale.
If it fits, no problem. Like it was mentioned before, you might have a ground loop problem.
#34 Post by DJPhatman »
The biggest problem with an in-cabinet plate amp will be ground-loop hum, as the sub placement will, in all likelihood, be nowhere near the rest of the components.
tomsza
#35 Post by tomsza »
DJPhatman wrote:The biggest problem with an in-cabinet plate amp will be ground-loop hum, as the sub placement will, in all likelihood, be nowhere near the rest of the components.
In my case, this monster is going behind my ht stuff in a corner.
tomsza
#36 Post by tomsza »
Last peek at the innards before I button up the side.
tomsza
#37 Post by tomsza »
Let the putty and sanding begin. The spot for the amp looks pretty good.
tomsza
Cabinet Stand
#38 Post by tomsza »
I put on the first coat of satin black last night and this puppy looks great. I read that for down firing, the mouth should be a minimum of 18" from the floor. Is there an optimum distance from the floor for this horn? I'm going to weld up a stand and I'm wondering if I should make it capable of height adjustment.
Re: Cabinet Stand
#39 Post by Bill Fitzmaurice »
tomsza wrote:I put on the first coat of satin black last night and this puppy looks great. I read that for down firing, the mouth should be a minimum of 18" from the floor. Is there an optimum distance from the floor for this horn?
That depends on whether it's wall or corner loaded and the cab width. You don't want the area of the opening between the bottom of the cab and the floor smaller than that of the mouth.
tomsza
Re: Cabinet Stand
#40 Post by tomsza »
It appears it will be corner loaded (see illustration 5 posts up).
tomsza
#41 Post by tomsza »
So if corner loaded, with a cabinet opening area of ~18"x26", it appears the minimum height would be ~10.64". That would save me some metal. :D
Melissa Goudeseune
#42 Post by Melissa Goudeseune »
What about having the mouth pointing up instead?
Simpler to build, less visual impact (it'll sit lower behind the TV), and it'll still be corner-loaded by the ceiling corner.
Just put a screen on the mouth ("pet screen" or similar) to keep anything from falling into the horn.
Built: THTLP 36"
Authorized BFM Builder
tomsza
#43 Post by tomsza »
Michel Goudeseune wrote:What about having the mouth pointing up instead?
That is an option. This room has a 12.5' cathedral ceiling and was thinking I might get better sound quality down firing. Reversing it would be more visually appealing. Where I plan on mounting the amp, it would still be out of site.
subharmonic
#44 Post by subharmonic »
I like up firing with that nice angle corner seems like it may be the perfect extension to the horn path.
I need more bass
CW Mcall
tomsza
#45 Post by tomsza »
subharmonic wrote:I like up firing with that nice angle corner seems like it may be the perfect extension to the horn path.
Sounds like a plan to start with. I just put the second coat of black on the cab. Tomorrow I'll do a little driver break-in and this big guy should be ready for prime time on Sunday. :hyper:
