Thanks guys, & yes the build bug has hit, & yes it's because I can't wait to play through them. Gonna start milling the Jack 112L's today, & maybe paint the insides/horns of the Wedgehorns.
BTW, I'm hoping that sharing the builds, as was suggested when I first signed on, is the
thing to do. Feels sort of strange that I'm just the new guy, & documenting what others have done as well (which, without seeing those builds, it would be much more difficult, I think for me).
So, to get to the last pic, I went & glued the lower back onto the bottom. This required cutting the lower back exactly to the proper dimension, then glued the sides onto that.  The access panel sides went on, and clamps & staples held it all to cure.
Made a couple of spacers per the plan (small ones), & used them to set the distance for the top. The box of wax paper stays next to me almost through the whole glue up process, as does paper towels and nitrile gloves. One side has the straight guide clamped on, the right side shows the spacers.
Once the guides are clamped, I just checked for proper spacing again. You can see the overhang from the bottom (the top has those as well). Next time (there I go again), I'll just cut them to the proper length.
Case left to cure.  Oddly enough, there was a little bit of bow in the side panels, going inward on all the sides. This will prove to be a good thing later on.
More detours.  Since the top of the baffle touches the top of the case, I just figured I'd make it square, & take care of a couple of birds with one stone.This is the sanding process on my granite plate (leftover from a friends kitchen remodel) tha I have sandpaper on to level parts for 'ukulele. Of course I hand planed it down most of the way first. The top of the baffle, facing down, is used as the guide to keep the top horn square.
This is what looks like after sanding.
Why go through all that to make it square? So I can just rip the bottom panel to the proper dimension, and be square. Here you can see the phase plug, and leftover pet screen, since this driver will be facing up all the time. Again, not concerning myself too much with the aesthetics on these parts.
P
You can never have too much clamps.  The top came a little loose so I secured it again. Access panel flanges being glued in. Yup, used leftover 1/2" from the jack build so I wouldn't have to double up the 1/4".
I did a test fit already, and although there's a couple of gaps which I'll show later, it's coming together pretty good.  I also saw on Bill's home page that the Wedgehorn build IS more difficult than the Jack. Don't feel too bad now.
More to come, probably in the new year.
Happy New Year!
Aaron
