I cheated a bit by having the external panels cut to size at the timber supplier (Mr Plywood) and had the remainder of the 3, 4 x 8 sheets cut to 18 inch widths. I feel that I may require additional timber for the bracing.
Using 4 double sided circular saw sleds, to take care of the angled cuts with accuracy along with an old protractor and sliding bevel. I took my sweet time and comfortably cut all the internal panels with ease over the weekend, without making any mistakes. (obviously I didn't spend the entire weekend cutting, had to still go about my daily responsibilities you all know the drum
Today my gear; PL jacks etc all arrived from SpeakerHardware care of ShipIto, both parties a pleasure to deal with. One final dash to the hardware netted me a $25 jigsaw, 4 175mm Quick action sliding clamps @ $5.98ea, 4 3 inch G-Clamps @ $6.02ea, 2 by 1 foot steel builders square @ $12.95, Packet of 20mm Chipboard screws $3.80, Super Araldite (epoxy) $10.02, 3.6m length of 70 x 35mm framing timber $7.35 (for gluing jigs, anti warping etc.) and a jumbo roll of baking paper from aldi for $2 something.
Made a start mid afternoon. Glued the top panel (1) for both cabs and set about preparing the baffle (2) and baffle backer. With the new jigsaw I made light work of the circular cut outs. I've chosen to build 2 and the BB together to prevent errors. I would have had the drivers trial fitted and hurricanes epoxied in position ready for the morning but......
My screws are too long for the single baffle which thwarted my attempts! Oh well, I still got both BB's drilled and trial fitted. The plans profess that single is fine (I probably can't spare the wood anyway) so will get some more screws at sparrows fart tomorrow. I'm photographing each step so that i can upload a visual chronology of my progress, just need to get some more panels glued up to free up some time.
Please chime in any time with tips that may assist me with the build cheers
