el_ingeniero wrote:Why the 2" paper cone tweeter? The smaller the tweet, the better the horizontal dispersion ...
True, but there aren't many tweeters that can smoothly cross at 4khz at that price point; you could even go to 3khz and perhaps flatten that large spike in response of the Sonys a bit better. I have considered piezos for this type of thing, but they are just too sensitive for home use (and especially with these woofers, 85db/w vs 94 db/w, that's a lot to even out, even with resistors)and would require trimming and gluing as well to minimize the center to center spacing which just makes things that much more complicated.
I mean, roughly, the dispersion will be about 90 degrees at 7khz, and, depending on cone break-up, it'll probably get lower from there and maybe start beaming at even higher frequencies. I don't think it'll be a big deal though because there are probably bigger factors affecting the overall sound, and I would be more concerned about the price and the raw response in the areas where it's more noticeable, like in the 2-7 khz.
rcko wrote:What type of wood should I buy?
1/2'' Arucuo if you can find it (usually at Lowes or Menards), but any 1/2'' cabinet grade plywood will do, at least 5 ply. If you can't find that, go for 1/2'' MDF which will work just fine as well especially if you plan on painting a nice high gloss finish.
