Alesis MEQ 230 EQ
djtrumptight
Alesis MEQ 230 EQ
#1 Post by djtrumptight »
Would it be a good move to incorporate my MEQ 230 into my rack with my DCX-2496 ? Im reading some things on the forum thats leading me to believe it would help to flatten my system better by mirror imaging it from the SPL chart.
Also,does anyone use the bandpass filters in the DCX-2496 to run DR's ?
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
djtrumptight
Re: Alesis MEQ 230 EQ
#2 Post by djtrumptight »
?????????? :conf:
2 SLA HT systems
2 SLA Pro's
Dantreige
#3 Post by Dantreige »
djtrumptight wrote:Would it be a good move to incorporate my MEQ 230 into my rack with my DCX-2496 ?
It could be. I think grabbing a slider is easier then navigating menues.
Flattening your system eq will not make it sound better, it's just easier to fine tune from that point, IMHO. You could tune your system outdoors using the dcx, use that as your starting point when you set up, then use the meq to fine tune the different venues.
I don't have one so I can't answer that.
Once you go Jack, you never go back!
Done:
(2) Jack 12, 3012ho, Straight Array with On/Off Switch
In Process
(4) Dr200 Beta 8, Melded Array
jcmbowman
#4 Post by jcmbowman »
I'm not sure what you mean by using the bandpass filters to tune the DR250.
I have mine set up with a HPF at 95hz (48dB LR) and LPF at 14k (12dB Butterworth). I also use the dynamic EQ to tame the upper mids when I push things hard, and have the limiter turned off because people will start going deaf before I have to worry about blowing the DRs.
Which bandpass filter are you referring to?
4 DR250s
4 Tuba36s @ 30" wide
2 ATs
djtrumptight
#5 Post by djtrumptight »
thanks for the input fellas.
Dantreige:I understand about flattening the response and using it as a starting point for fine tuning.According to forum member Sydney,no one listens to music flat but i do like the idea of having a 31 band EQ in the rack to make finer adjustments without (as you mentioned)having to navigate menu's.
JC:I was referring to the different filters for each eq where you have a choice of HP\LP\BP,the BP also affects the frequencies "around" the specific frequency.I'm going to try your set up and see how it sounds,i'm low passing at 18k.I have a luau to DJ for my cousin 2morrow night in a big field so maybe i will get there a hour or two early and do some experimenting.When is your next set up ? I would like to come here those 4 T-36's bang ! Thanks again fellas.
2 SLA HT systems
2 SLA Pro's
jcmbowman
#6 Post by jcmbowman »
djtrumptight wrote:thanks for the input fellas.
Just a note - the LPF I have on the DR250s is set at 12dB/octave to give it a gentle taper off - it helps to tame the "harsh" out of the piezos.
4 DR250s
2 ATs
