Come watch a noob try to not screw up an Omni 15 TallBoy!
Re: Come watch a noob try to not screw up an Omni 15 TallBoy
CaseFAceMcGee wrote:Dad Gummit - so close! I think the woofer slap is taken care of, but I can't tell because the mid driver slaps more than the three stooges when I turn it up.
It shouldn't, even at full power excursion will be no more than a millimeter if the crossover is correct.
Rick Lee
#17 Post by Rick Lee »
CaseFAceMcGee wrote: I think the woofer slap is taken care of, but I can't tell because the mid driver slaps more than the three stooges when I turn it up.
Uh-oh. Either the grill is vibrating or the xover may be wired wrong.
Authorized Builder
Nashville/Middle Tennessee
bwtaudio@gmail.com
CaseFAceMcGee
#18 Post by CaseFAceMcGee »
It wouldn't surprise me if the crossover wasn't quite right, I'll probably be able to check it tomorrow.
The cab worked great at rehearsal. I am in a swing band, competing against 5 trumpets who all think they are playing 1st :roll: My Little Mark III was set with gain and master volume just over 9:00, and it was plenty of volume.
http://s301.photobucket.com/albums/nn68 ... 0pictures/
Tom Clement custom 5 fretted and 4 fretless, no-name upright, MarkBass Little Mark III
Omni 212TB fullrange, Jack 10
CaseFAceMcGee
#19 Post by CaseFAceMcGee »
Getting two new hurricane nuts today - I managed to mess up the threads. The grill should be built in the next few days.
Edit: also getting different 1" screws for the top handle and wheels - wood screws look funny there.
CaseFAceMcGee
#20 Post by CaseFAceMcGee »
I spent some time tracking down the buzzing that I heard, and as far as I can tell the mid driver is fine. The two side handles, on the other hand, were buzzing like crazy. I took them off for now, to find other noises they may be covering up, and I've gotta figure out how to eliminate their rattling.
Now I can hear that the tweeter is either buzzing or distorting... it seems to happen almost exclusively in the lowest two octaves of my 5-string - the lower I go, the worse the sound is. How would I be able to figure out if the tweeter is distorting?
On the plus side, when the volume is down low enough to avoid the tweeter madness, it sounds like butter.
#21 Post by DJPhatman »
Cross-over problem, again. If you are playing a note lower than the band-pass of the tweeter, it's a cross-over issue. Triple check the wiring and the mid to high crossover.
CaseFAceMcGee
#22 Post by CaseFAceMcGee »
Thanks, that's a task for tomorrow or Thursday. Is there a way to tell if I fried a cap or coil or something? I did a cursory check of the crossover today and didn't see any issues, so next chance I get I'll make a schematic just from looking at my crossover and compare it to the one in the plans.
CaseFAceMcGee wrote: Now I can hear that the tweeter is either buzzing or distorting... it seems to happen almost exclusively in the lowest two octaves of my 5-string - the lower I go, the worse the sound is. How would I be able to figure out if the tweeter is distorting?
Disconnect it. I bet it's not sealed well enough to the cab and is vibrating.
CaseFAceMcGee
#24 Post by CaseFAceMcGee »
:wall: :wall: :wall: :wall: :wall: :wall: :wall: :wall: :wall: :wall: :wall: :wall: :wall:
I had a huge post that I had typed up over the course of my diagnostics, almost complete, when FireFox decided that it would be a good time to crash and lose all of it. Hopefully I remember to include all the important stuff...
This revamped version is brought to you with help from Pulp Fiction and Jim Beam.
Bill Fitzmaurice wrote:Disconnect it. I bet it's not sealed well enough to the cab and is vibrating.
I tried that, no dice. The buzzing is coming from the tweeter, and the mid driver also. I double checked the crossover wiring, and I found nothing that didn't appear to match up with the schematic in the plans. I checked all wires to make sure the negative was actually the negative, and same with the SpeakOn cable - no issues found.
My wiring setup has a few feet of speaker wire running from the SpeakOn toward the crossover. Three 8-inch wires connect to this jumper wire, then connect to the three crossover sections. The crossover sections connect to the speakers through equal-length wires, about 4 feet each.
I'm pretty much out of ideas as to what's going on with it :noob: The only thing that I can think of is crosstalk between the crossover components or the speaker wire, but I don't know if that would cause this much of an issue. The speaker wires do get very close in spots due to my current wiring configuration - I've been planning on running the wires more cleanly once everything is working properly. The distortion only happens in the lowest register, the lower I go the worse it gets, and it is very noticeable at the start of a note with the amp at about 40% volume and 40% or less input gain. The input is not clipping. I have also gotten the distortion while running a sine wave, 100hz, from my laptop through the amp. As I said, the noise is in the tweeter and the mid driver. I did not notice any distortion in the woofers.
#25 Post by DJPhatman »
And like I said, if you are hearing 100Hz through the mid or HF driver, you have a crossover problem. :roll:
The crossover's job is to send the correct frequencies to the correct driver. 100Hz should be 100% to the woofer. If you get it in the mid driver, or the HF driver, there is a problem with the crossover. Take pictures of the crossovers and wiring and post them so we can spot any problems. BTW, it may be a bad component in the crossover.
CaseFAceMcGee
#26 Post by CaseFAceMcGee »
You were right DJPhatman, it is definitely a crossover-related issue, but for the life of me I can't figure out where. I have three crossover pictures here that show the crossover and the mess of wires currently surrounding it. I would throw together labels in MSPaint, but I've gotta be at work in less than 8 hours and I still need to shower and cook supper. Crossover sections are Low-Mid-High from top to bottom in all pictures. Tomorrow I can pull the crossover from the cab and make a labeled picture of it.
#27 Post by Bill Fitzmaurice »
CaseFAceMcGee wrote:You were right DJPhatman, it is definitely a crossover-related issue, but for the life of me I can't figure out where..
No surprise that, with all that stuff on one board. That's why I recommend that each filter be mounted on its own board, so that you're less likely to get confused with all the components and wires.
CaseFAceMcGee
#28 Post by CaseFAceMcGee »
Bill Fitzmaurice wrote:No surprise that, with all that stuff on one board. That's why I recommend that each filter be mounted on its own board, so that you're less likely to get confused with all the components and wires.
That's one change that I plan on making - splitting up the three boards, mounting them separately. I went off the layout for another board that I found on this site, but mine apparently didn't work out as well.
#29 Post by DJPhatman »
Or, better yet, have Leland make it for you. I'm sure he'd be glad to, plus he'll probably test it before he sends it to you. Worth the price, IMVHO.
CaseFAceMcGee
#30 Post by CaseFAceMcGee »
DJPhatman wrote:Or, better yet, have Leland make it for you. I'm sure he'd be glad to, plus he'll probably test it before he sends it to you. Worth the price, IMVHO.
I was considering that when I ordered the parts, but I thought I would save a few bucks and learn something by doing it myself... my guess is my awesome soldering skills were too awesome for a few of the caps. After I'm done with work and a much-needed bike ride today, I'll be (carefully) desoldering the connections, which I'm guessing will resemble this :chainsaw: , then if my multimeter cooperates I can hopefully diagnose whether I've got some dead components.
