Can it be done, and if so, what do you suggest. I know, spend 2k probably.
But all answers appreciated.
bzb wrote:Don't go cheaplights.
Does $1k include stands/t-bars/truss, or you have this covered already? Good trussing will eat up that budget.
And along those lines, do you want trussing over the band/DJ, or just two T-bars in the corners, or just a single T-bar?
It can be done, but it totally depends on what effect you're going for. For example, at over half of my gigs I use:
Global Truss ST90 crank stand and T-bar: $150
1 Chauvet ColorStrip: $180
1 Martin EFX 600: $500
DMX junk: $150
4 LED uplight cans on DIY stands: $300
So I'm a little over your budget, but you don't have to get the uplighting. And you certainly don't need the Martin EFX - I just really like the effects it produces and I've programmed some pretty good DMX shows with it.
There's a couple LED scanners that are out now that I really like, they're about $200 each for Chinese knockoffs. I think the ADJ ones (which the verdict is still out on) are around $250.
*shrug* my suggestion is simple to me.James R wrote:He said a simple setup, there's a 4 pack with stand and floor controller for around 400.00 or you can go ebay as i did got 12 Par 64 leds, Mydmx software to run them and then I bought 2 sets of DJ truss with 13 foot stands for a little over 1300.00
THose pucks are pretty badass for the $$.LiefStevens wrote: The pucks are very well made and I love that they don't take up much pack space.
