2 x 3000 watts @ 4 ohms..HOW??
Is this amp OK?
NCcrashman
#1 Post by NCcrashman »
So, applying what I know about amps (2400 watts MAX with 120 volt wall socket) I called Behringer tech support to ask them how their new iNUKE NU6000 could produce such numbers. The only answer they had was what I thought they would say "switchable power supply and class D technology".
My question still stands: if the max you can get from a 120 wall socket and a 20 amp service is 2400 watts, how are they getting 6k from this amp? Is the answer, they're not?
"If it's too loud, your too old! What's that? I didn't hear you"
Friends don't let friends use crappy speakers!
doncolga
Re: 2 x 3000 watts @ 4 ohms..HOW??
#2 Post by doncolga »
NCcrashman wrote:So, applying what I know about amps (2400 watts MAX with 120 volt wall socket) I called Behringer tech support to ask them how their new iNUKE NU6000 could produce such numbers. The only answer they had was what I thought they would say "switchable power supply and class D technology".
Pixie Dust!
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
Rune Bivrin
#3 Post by Rune Bivrin »
It's all a matter of measurement technique and energy storage. If both your conscience and the caps in the power supply are large enough you can get almost any number of watts out for a very short period of time. Power is really an instantaneous measure, even if we are usually interested in average power. So 6000 Watts at a single peak of a 20Hz wave isn't beyond the impossible. It's just continuously that it's impossible.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
Israel
#4 Post by Israel »
a simple response to that they are at 4 ohms 6000 w at 4 ohms are sort of 1500 w of ac power..... of course momentary power of that amount will only be possible in optimal conditions i mean try to hook 2 or 3 of these and get 6000w from each one of them..... besides of the usefulness of 6000w
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
#5 Post by Bill Fitzmaurice »
NCcrashman wrote: Is the answer, they're not?
Not continuous they aren't.
imnotded
#6 Post by imnotded »
Part of the problem is that not every manufacturer measures the rating of their speakers or amps the same. More so in the speaker category but you can see it in amps as well. They were able to measure 6k watts our of that amp, what we dont know are the conditions.
BFM cabs:
4 - OT12 (2512 loaded w/ melded arrays)
4 - T39 (3012LF loaded, 20" wide)
NCcrashman
#7 Post by NCcrashman »
I kind of figured that out after asking the question..lol. I remembered CONTINUOUS and PEAK. I tell ya what, I know a several local guy's running sound and while I'm a pup here, I'm a damn mentor to these guys. They simply don't "get it". They are running sound without a decent fundamental knowledge of how this stuff works and they don't even care to learn. Sad indeed.
Thanks for all the brilliant responses.
-Patrick-
Mikey
#8 Post by Mikey »
Behringer has ALWAYS been shady about their advertised power ratings. About the best you can do is go to a brick-n-mortar store that has it in stock and ask that the output voltage be measured before purchase. If they have nothing to hide, they shouldn't have a problem doing it for you.
I seldom see 20A breakers for the stage in clubs. They're usually 40A. Small bars, yeah, but you don't need mega-watts there, anyway.
Albert Einstein
Dave Non-Zero
#9 Post by Dave Non-Zero »
It's nice living in the civilised 240v world... ;)
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
