Jack 15 bass cab
Preston
Jack 15 bass cab
#1 Post by Preston »
Baltic Birch, 3015, no tweets. This cab replaces an old school Peavey 4x12 Black Widow loaded bass cab. I just finished rehearsal with the Jack. I can lift the jack easily enough with one hand. I can barely pick up the Peavey at all. The Peavey is a 4 ohm cab, the Jack is 8 ohm. One driver vs four in the Peavey.
I honestly thought I'd need two Jacks to keep up with the Peavey. I don't. In fact, the Jack is easily louder at the same amp settings, responds better to eq, and has a much richer, fuller tone. The entire band commented on how good it sounds.
I'll be gigging it this Saturday in a good sized room without PA support, and will post an update afterwards.
How does it sound? It was articulate and focused and still had "girth." I felt that the cab actually did what it was supposed to - reproduce what I was playing - instead of coloring the sound, and that it would take anything I was capable of throwing at it.
P-bass w/flats. T-Max. 70's and 80's classic rock. no effects.
Re: Jack 15 bass cab
#2 Post by Chris_Allen »
Sounds good so far - it will be interesting to hear what you think. I don't believe there are many (any?) vanilla Jack 115 reviews.
BTW, we want pictures! :cussing:
Harley
#3 Post by Harley »
I have the driver, I have the piezos, I have the wood, I have the fittings.....the only thing I don't have...is the time.
So many cabs....so little time :broke:
So yeah...this review will be watched with interest :mrgreen:
Mikey
#4 Post by Mikey »
Love to see some pics!
Albert Einstein
Preston
#5 Post by Preston »
Fresh back from the first gig with the Jack 15. Good sized room, one of the larger clubs in area, high ceilings, about half full of "water bags." I was not in the PA and had to carry the room with "just" this one little cabinet and about 200 watts. (Peavey T-Max)
The band plays loud, 60's, 70's, 80's classic rock. The Jack performed flawlessly and effortlessly. I had the gain on about five and the master just shy of 4. I dialed up my usually settings on the amp and quickly found I was too loud... way too loud. A couple tweaks and I had a nice fat, growly tone that filled the room and sat perfectly in the mix.
I have nothing but praise for this cab. The end of the night load out was a breeze too!
Here's the pics:
Gauss
#6 Post by Gauss »
:clap: Very, very cool. I was going to ask about the dispersion, but with the flats, I guess you're not going to far into the upper range anyway. Did you notice a difference from dead-on compared with off to the side? Does the horn on the Jack change the usually narrow dispersion of 15 inch speakers?
BASS: Combo Amp & Titan39
Haysus
#7 Post by Haysus »
Nice job. :clap: The pic really shows the size of the cab. Kind of like the first time seeing a WH8 to a WH10.
I have been contemplating some jacks for light duty PA and I might like the size of a 10 or 12.
4 20" T39(built)
2 WH8(built)
3 WH10(own)
4 DR200(own)
1 Jack 12(built)
SAC 24 Channel Mixer
SAW STUDIO Recording
Preston
#8 Post by Preston »
As far as bass cabs go, this is tidy little cab, but I think many would find it a little large for use as a PA main, at least when compared to other BFM offerings. I used to manhandle original Peavey SP-2's up on speaker stands... compared to those, and many other comercial designs, the Jack-15's seem pretty nimble.
Although I didn't specifically check dispersion, everything seemed really even, and I didn't detect any beaming.
I did learn that I need to elevate the cab or tip it back so that I get a better idea of how loud I'm playing. I'll be making a very high tech seismic vertical alignment audio management system: probably a piece of 2x4 painted black. :wink:
Preston
#9 Post by Preston »
BTW, the Marshall pictured next to the Jack is a 2x12, not a 4x12. (for size reference) The T-Max is a standard 2 rack space size.
dcodym
#10 Post by dcodym »
Do you get any rattle or a flapping noise of any sort from the pet screen on the baffle like that?
Preston
#11 Post by Preston »
no flapping or vibration at all that I could see or hear. I did it just like in the plans, and it worked great. This is the first cab I haven't put a full grill on, and I'm finding I really like this look. I was most worried about the handles vibrating, but I didn't notice anything from them either. I forgot to order handles with my kit, and just used some I found at Lowe's.
Dave Non-Zero
#12 Post by Dave Non-Zero »
Preston wrote:BTW, the Marshall pictured next to the Jack is a 2x12, not a 4x12. (for size reference) The T-Max is a standard 2 rack space size.
haha if that was a 4x12 then the jack would be a pretty big cab! :)
that is one majorly overloaded lighting bar by the way! wow i wouldnt want to be that drummer....
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
J15 is smaller overall than a typical 4x10, and less than half the weight of most. It won't fit in a Miata, but bassplayers don't drive Miatas.
Harley
#14 Post by Harley »
Bill Fitzmaurice wrote:.... It won't fit in a Miata, but bassplayers don't drive Miatas.
Certainly not in this country - Miatas simply don't exist, we call them MX5s and the steering wheel is on the other side for the singers... :mrgreen:
dcodym
#15 Post by dcodym »
Preston wrote:no flapping or vibration at all that I could see or hear. I did it just like in the plans, and it worked great. This is the first cab I haven't put a full grill on, and I'm finding I really like this look. I was most worried about the handles vibrating, but I didn't notice anything from them either. I forgot to order handles with my kit, and just used some I found at Lowe's.
Awesome, thanks. I'm going to be using a grille cloth, but I want to put the pet screen on there anyway. I figure, in the future, I can easily pull the grille cloth off, but there's no way to go in and add the pet screen on the baffle.
