cry.What if there's a leak in there somewhere?
It will make sure that next time you make one of these that you'll be checking three times before progressing on any of the next steps - plus making up a check list for yourself.CharlesC wrote: What if there's a leak in there somewhere?
For you HarleyHarley wrote:Oh...and it will teach you to leave the fridge door shut until you've finished up in the workshop for the day/night
Total waste of money on Bill's designs. The screws don't even need to be left in once the adhesive has cured. Most of the builders now use pneumatic brad nailer.CharlesC wrote:I forgot to mention. I had read in some post somebody recommended using pocket hole screws instead of drywall screws. Tremendous suggestion. They work much better imo.
Sorry, bro. I don't do touch-ey-feel-ey. Straight-forward, no nonsense, no B.S. from me.CharlesC wrote:Gah you guys provide no consolation.
We let you off lightly - Mr Green is the best consolation you can getCharlesC wrote:Gah you guys provide no consolation.
 Once you're part of the furniture here, you normally get
  Once you're part of the furniture here, you normally get   for your cock-ups.
 for your cock-ups.
Aawe...shuckks....thanks Antonz. You're a real cobberAntonZ wrote:For you Harley
No doubt the PL is plenty with all the glue surface involved. In fact with my 18" wide cabinet I'm surprised there's even a need for the braces. But even if you plan to remove the screws they're better. They go in much easier (self tapping) and are thinner so they don't bust out the wood so easy.DJPhatman wrote: Total waste of money on Bill's designs. The screws don't even need to be left in once the adhesive has cured. Most of the builders now use pneumatic brad nailer.
Don't sweat it, messy PL is goodCharlesC wrote:What a damn mess.
 Tried to look up "cobber" in the online dictionaries, failed. I will take it as a kiwi complimentHarley wrote:Aawe...shuckks....thanks Antonz. You're a real cobber
cobber [ˈkɒbə]AntonZ wrote:Tried to look up "cobber" in the online dictionaries, failed. I will take it as a kiwi compliment
it's strange to think that some people in the world grew up without the influence and education provided by Neighbours and Home and Away.Tried to look up "cobber" in the online dictionaries, failed. I will take it as a kiwi compliment .
Use a bright flashlight in a very dark garage. Shine it down the space in the adjacent panel all the way to the bottom. Look down the opposite side of the panel. If you see light apply more PL if not light move on, you may have to use a stick or something to get the PL down. It is a huge pain. But I found and fixed like 10 leaks on my 27" T60 doing this, and is better to find them now.CharlesC wrote: I'm finally realizing that I'm not going to be able to get in between panels 3-5 and 4-6. I guess you just have to pray everything's airtight? What if there's a leak in there somewhere?
