My meter won't go high enough to measure this unfortunately. The meter just flashes 'over' when it gets above aboit 127dB.
T60 with a 40hz test tone peaking my SPL meter
Forum rules
- Dave Non-Zero
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
ben.in.salzburg
Re: T60 with a 40hz test tone peaking my SPL meter
Try stepping back 100m and repeating
Regards, Ben
Regards, Ben
- Dave Non-Zero
Ahhh, is that how it's done.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
that sound is brutal.....
MissileCrisis
Specs on the T60? As in how wide / is this a 12/15 loaded? Corner? How far was the mic from the sub? What's the max output you can get at 25 Hz? I'm sure that would be fun to try.
2 x TLAH
1 Titan 39 (lab 12, 15 inch)
1 Tuba 60 (lab 12, 20 inch)
SLA Center
2 x Mini MLTP subwoofers
1 x 212 TH (custom)
2 x Mini-Karlsonators
Owned, but not built
2 x Jack 12 (2512, melded)
2 x TLAH
SLA Center
1 x 212 TH (custom)
+1 but not at exactly 100m.ben.in.salzburg wrote:Try stepping back 100m and repeating
Regards, Ben
You lose 6db for each doubling of distance, so you can use that to calculate your loss due to distance and arrive at a total at 1 metre.
So, your mike would be at 1, 2, 4, 8, 16, 32, 64, 128m etc
And your reading would be + 0, 6, 12, 18, 24, 30, 36 (etc) dB on what you see on your SPL meter and the corresponding distance.
Hope this helps...
MissileCrisis
How many volts were you juicing it with
2 x TLAH
SLA Center
1 x 212 TH (custom)
2 x TLAH
SLA Center
1 x 212 TH (custom)
