Introducing SPL Chart
Re: Introducing SPL Chart
#181 Post by Chris_Allen »
Unfortunately at work, so don't have access tot he tools :(
Harley
#182 Post by Harley »
J110 vs W10
DaveK
#183 Post by DaveK »
Harley wrote:J110 vs W10
Showing for the umpteenth time that bigger is louder :-)
Harley
#184 Post by Harley »
Actually, just working out if I should use my spare J110 as a monitor with FOH mix or go to the hassle of building another W10. I like the shape of the W10 for a monitor and was surprised it was louder - decision made really :fruit:
DaveK
#185 Post by DaveK »
Harley wrote:Actually, just working out if I should use my spare J110 as a monitor with FOH mix or go to the hassle of building another W10. I like the shape of the W10 for a monitor and was surprised it was louder - decision made really :fruit:
Not an apples-to-apples comparison. The W10 box is roughly the same size as a J112 and has similar response. The J110 is smaller and not as loud. That was the source of my comment that bigger is louder.
Dan30
#186 Post by Dan30 »
Are there any charts available for the TLAH Pro? I want to compare it to the SLA Pro.
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
Harley
#187 Post by Harley »
Chris - are there any charts for;
J112 Melded piezos and 3012HO?
J115 Melded piezos and Kappalite 3015 ?
Also, is the J110M12 chart for the DLII2510?
#188 Post by Chris_Allen »
I'm finally updating the charts, so I'm looking for the gaps:
JBL SRX728
TT's
#189 Post by Chris_Allen »
Dan30 wrote:Are there any charts available for the TLAH Pro? I want to compare it to the SLA Pro.
Had a good luck but I can't find one.
#190 Post by Chris_Allen »
Dual driver Tuba 60
#191 Post by Chris_Allen »
I've now included an experimental '+' symbol - it will increase a map by a certain number of dB's that you specify:
Code: Select all
[spl]T48W24D3015+6,T48W24D3015&dbmin=80&fmax=200[/spl]
Not quite sure on the '+' char on the naming, so it might change. I've also increased the default width to provide more space.
BassMe
#192 Post by BassMe »
Does anyone have TT with tang band in it?
#193 Post by Bill Fitzmaurice »
Chris_Allen wrote:
TT's
I need to redo that one. The response will flatten a lot more with the reduced space loading. That chart dates back to the very early days, both HornResp and my charting skills have improved a lot in the interim.
#194 Post by Bill Fitzmaurice »
Fixed it, this is the updated TT chart.
Jon Barnhardt
#195 Post by Jon Barnhardt »
Chris, any chance you can add the ls yorkville subs? Namely the ls1208 and ls808 subs?
Thanks!
