Mama's new toy.
Re: Mama's new toy.
how much vertical space is under the front seats?
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
1x bastard XF208
Re: Mama's new toy.
I have to make some measurements this weekend. I will post them.
- Harley
Re: Mama's new toy.
80mm is all you need for a good bottle or two of Shiraz ( laying down ).sine143 wrote:how much vertical space is under the front seats?
Re: Mama's new toy.
Will those shure chip amps run off a 12v hookup?Drey Chennells wrote:ncool options like a sweet little 2050 chip amp and your ipod to some micro sound pods mm..
- Drey Chennells
Re: Mama's new toy.
yes, 10-30v. I have 1 of these, very cool..
http://www.parts-express.com/pe/showdet ... er=320-302
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
InfraCoustik
Re: Mama's new toy.
What power supply? I'm thinking one for satellites and another for the subs...of course i'll I need some kind of DIY crossover.. HAHA!Drey Chennells wrote:yes, 10-30v. I have 1 of these, very cool..
The goal here is cheap, efficient and well...above average sounding!
They say good fast and cheap pick one. I'll just take good and cheap!
I'm totally open to ANY suggestions, smaller and more efficient the better.
- Drey Chennells
Re: Mama's new toy.
I have dozens of supplies and tried several. PC ps, laptop, wall wart, batteries, they'll all work for these, just match the output range to amp of course..
InfraCoustik
InfraCoustik
Re: Mama's new toy.
Drey Chennells wrote:I have dozens of supplies and tried several. PC ps, laptop, wall wart, batteries, they'll all work for these, just match the output range to amp of course..
So basically I just need a 12v adapter that fits the jack connector on the amp or do I need an actual 12v power supply with the connector that fits the jack on the ranger?
- Drey Chennells
Re: Mama's new toy.
nope don't need a jack. these have a jack power input or bare wire terminals specifically for ranger installsnetwerks wrote:Drey Chennells wrote:I have dozens of supplies and tried several. PC ps, laptop, wall wart, batteries, they'll all work for these, just match the output range to amp of course..
http://www.parts-express.com/pe/showdet ... er=070-675
InfraCoustik
InfraCoustik
Re: Mama's new toy.
Sounds like amp problem solved...now for speakers and sub config. hmmmm.Drey Chennells wrote:nope don't need a jack. these have a jack power input or bare wire terminals specifically for ranger installsnetwerks wrote:Drey Chennells wrote:I have dozens of supplies and tried several. PC ps, laptop, wall wart, batteries, they'll all work for these, just match the output range to amp of course..
So basically I just need a 12v adapter that fits the jack connector on the amp or do I need an actual 12v power supply with the connector that fits the jack on the ranger?, just run a fused hot wire..
Re: Mama's new toy.
Do you have a link to these?Drey Chennells wrote:micro sound pods mm.
- Drey Chennells
Re: Mama's new toy.
ah you know roll your own a dozens ways like your standard resin based pod w rat fur or fiberglass for ex.. cut a baffle to fit your space and fasten your favorite 2" fullrange to, use a plastic bowl or cup with the pod shape you want and mates well with your baffle, presto
http://www.parts-express.com/pe/showdet ... er=299-249
InfraCoustik
InfraCoustik
Re: Mama's new toy.
For sure. I'm gonna come up with something.Drey Chennells wrote:ah you know roll your own
Re: Mama's new toy.
Maybe I can rig these up somehow and mount in rear....right and left facing in.
http://bierbower.net/diytower/Dans%20Speaker%20Cans.htm
http://www.amazon.com/Polk-Audio-5-25-I ... 707&sr=1-9
or maybe even as small as these
http://www.amazon.com/Polk-Audio-4-Inch ... 97&sr=1-36
