That is the setup. Now the question...why the hum?
A week later I brought a 12v car battery in, installed in place of the PSU and everything worked well.
It's a PSU, and I have two more which I thought I'd try work in trio, perhaps using a diode trio if need be (I have a spare one available). Interesting that you said that it can pull 75A because another amp that I had in the car was protected by only a 20A fuse and it never blew(this amp has a 60A). Granted, it was an Audiovox 60 x2.Splatmaster527 wrote: If its a PSU its most likely very underpowered since a 500Watt car amp would pull easily over 75A of DC current.
Anyway to the question. You have ground loop. In a car the amp and the source (head unit) share a common ground (car frame/body) in this situation you are sending a signal from a source with a different ground.
http://www.radioshack.com/product/index ... Id=2062214
Something like that should help your problem. Or maybe even just ground the amp to the earth ground somehow...
I'll try a different sound source.CoronaOperator wrote:Sounds like ground loop to me. Take a DMM and measure the voltage across the negative of the psu and the negative of the stereo speaker wire that your using for signal. If there is a measurable voltage you will get ground loop noise. Try using an ipod/mp3/cell phone as your source signal along with the psu. If the hum dissapears you have a ground loop, if not its not ground loop noise and most likely your psu has major ripple which some automotive battery chargers tend to do. If your dead set on using the psu, and you have determined that the noise is from a ground loop, then a ground loop isolator will eliminate the problem.
http://www.thesource.ca/estore/product. ... ct=2700054
Before I would purchase one of these I would first try grounding your amplifier chassis directly to the stereo receiver chassis, just some left over speaker cable should suffice
+1 on this.Israel wrote:which power supply are u using?? you can make one out of an old desktop power supply
