Hand held belt sander good or evil??
rec
#1 Post by rec »
Still trying to determine that.....ha ha
Broke out the ole craftsman belt sander left to me by my father.
3'x21" belt. I put a 80 grit belt on it and whoa it definitly removes material like
right now. I think this will be good for the edges of my cabs where the boards come together. Mine are not always perfect. I also bought 120 grit belts, I think these my be safer for me to use.
My 2 cents
My initials are in the view finder of every camcorder (REC)
2xOT12(Deltalite 2512 loaded, w/melded arrays)
2xOT12(Deltalite 2512 loaded, w/flat array) "In Process"
4xT30(24", 4012HO loaded)
1xAT
Re: Hand held belt sander good or evil??
#2 Post by Bill Fitzmaurice »
I almost never use my belt sander. Random orbit is the way to go, with which I use 40 grit discs.
petegt
#3 Post by petegt »
I have sanded the edges and the corners of my tat with a belt sander and it was easy to do and came out well.
2 TAT 16" loaded with JBL GTO 804 + V plate
Tannoy Precision 8D monitors, Tannoy System 800 monitors
Minidsp 2x4, Berry DCX2496, Lem 420 amplifier
To do:
17" Autotuba with JBL GTO 1002D 10"
Benj Ross
#4 Post by Benj Ross »
Much like guns and people, belt sanders dont ruin projects, people ruin projects. If you can control it, it is a great tool that you use for a lot of things. For many applications I like to screw a belt sander to the bench and handle the workpeice instead. Just take it nice and slow and it'll do ya right.
Benj
Authorized Builder
http://www.westsoundsystems.com (under construction)
Donating a portion of all proceeds to the Friends of Falun Gong
http://www.fofg.org
Peavey and Madisound Dealer
bzb
#5 Post by bzb »
I use belt sanders on two things: 4/4 table top glueups and concrete.
Personally, I wouldn't take a belt sander to 1/2" plywood. I'm with Bill on the RO sander - plus they are really good at dust collection.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
rec
#6 Post by rec »
I think it is usable I just need to get used to it
80 grit is a little too agressive
1xAT
