I think I'll need a third anyway since I'm bound to screw at least one cut up.
Birch vs MDF
Re: Birch vs MDF
Almost got all the pieces from 2 5x5 sheets.
Re: Birch vs MDF
el_ingeniero wrote:Actually, the Menards in my area carry 4x8 sheets of BB at 1/2" and 1/4". It's the real thing, the 1/2" stuff has 9 even sized plies and no voids.
So I called my local Menards... they have it too. 4x8 sheets. $0.01 more per sq ft than the other lumber yard with the 5x5 sheets.subharmonic wrote:My local Menards has 1/2" Acura ply (ask for hobby grade or furniture grade ply) and 1/2" BB.
I guess I'll go there since I could get all my cuts out of 2 sheets and save some $$ over wasting most of a 3rd 5x5 sheet. So thanks for the heads up!
All that ^^ work in CAD... WASTED!
To be fair, I don't think they didn't know what it was, they just don't carry it. Actually, the guy at the first place kept repeating "Malted Birch?" but since he said they just had standard birch I didn't feel the need to correct him.subharmonic wrote:And like Bill said I would be nervous about any lumber shop not knowing what BB is, that is like a car parts store checking stock on blinker fluid.
				el_ingeniero
Re: Birch vs MDF
You're lucky. Here, the best price for 5x5 sheet of 1/2" BB is $43 each.chjade84 wrote:el_ingeniero wrote:Actually, the Menards in my area carry 4x8 sheets of BB at 1/2" and 1/4". It's the real thing, the 1/2" stuff has 9 even sized plies and no voids.So I called my local Menards... they have it too. 4x8 sheets. $0.01 more per sq ft than the other lumber yard with the 5x5 sheets.subharmonic wrote:My local Menards has 1/2" Acura ply (ask for hobby grade or furniture grade ply) and 1/2" BB.
All that ^^ work in CAD... WASTED!![]()
Re: Birch vs MDF
The two lumberyards I get mine from know it as two different things.  The one that supplies construction materials just calls it Russian birch, the one that carries all the specialty hardwoods calls it Baltic.  From what I can tell, they come from the exact same place with the same markings on the ends.
									Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
Re: Birch vs MDF
Yea, 5x5 sheets are $41.19 and the 4x8 sheets are $52.99.el_ingeniero wrote:You're lucky. Here, the best price for 5x5 sheet of 1/2" BB is $43 each.
3 x $41.19 = $123.57 but 2x $52.99 = $105.98
So I'll save $17.59 + the extra gas for the additional 40 min round trip it would take me to get to the lumber yard that's NOT 5 miles from my house.
That makes some sense considering it's, I guess, from the areas near Russia which is right near the 'Baltic' states.bzb wrote:The two lumberyards I get mine from know it as two different things. The one that supplies construction materials just calls it Russian birch, the one that carries all the specialty hardwoods calls it Baltic. From what I can tell, they come from the exact same place with the same markings on the ends.
Re: Birch vs MDF
Well I got all the info I needed from you guys - and all in 1 afternoon!  Thanks!
Mods, feel free to move this thread to a more relevant section; if there is one. I originally posted it here since it was a quick question about building a TT, but since it's turned into quite the discussion on wood, perhaps it would be better suited for a different sub-forum.
Re: Birch vs MDF
Naaaa. Thread hi-jacks are so common around here, it's when it doesn't happen that you start to wonder!chjade84 wrote:Mods, feel free to move this thread to a more relevant section; if there is one. I originally posted it here since it was a quick question about building a TT, but since it's turned into quite the discussion on wood, perhaps it would be better suited for a different sub-forum.
Re: Birch vs MDF
you should be careful of the 4x8 sheet that claims to be birch, most of them are chinese birch...stay away from these chinese birch that have thin laminate layers on the outside
btw
use this program to plan out your cutsheet; it's faster than trying to do the layout in cad
http://delphiforfun.org/programs/cutlist.htm
						btw
- BrentEvans
Re: Birch vs MDF
When I went looking a while back, I found some "Russian Birch" at a local yard that had the veneers. Never hurts to check.bzb wrote:The two lumberyards I get mine from know it as two different things. The one that supplies construction materials just calls it Russian birch, the one that carries all the specialty hardwoods calls it Baltic. From what I can tell, they come from the exact same place with the same markings on the ends.
99% of the time, things that aren't already being done aren't being done because they don't work.  The other 1% is split evenly between fools and geniuses.
						Re: Birch vs MDF
I have never had an issue with MDF. I used to always build sub boxes, and even built a few for the marine enviroment and with the moisture I havn't run into any issues. I do give it a thumbs down because if you do drop it and its a hard fall it can split unlike plywood which has a little give, but for the most part I really had no issues with MDF.
						Re: Birch vs MDF
MDF is fine for home audio since you don't move them around much. But for live sound and mobile dj's, moving a truck load of horn cabs made from MDF can be tiresome from all the weight.loudsubz wrote:I have never had an issue with MDF. I used to always build sub boxes, and even built a few for the marine enviroment and with the moisture I havn't run into any issues. I do give it a thumbs down because if you do drop it and its a hard fall it can split unlike plywood which has a little give, but for the most part I really had no issues with MDF.
Re: Birch vs MDF
This appears to be the good stuff. 9 plys all the same thickness.BoostFab wrote:you should be careful of the 4x8 sheet that claims to be birch, most of them are chinese birch...stay away from these chinese birch that have thin laminate layers on the outside
Here's the build thread.
http://billfitzmaurice.info/forum/viewt ... 30&t=14089
Re: Birch vs MDF
Yeah I would not want to be lugging around all that weight...plus if you dropped a cab I would fear it exploding vs the extra give plywood adds.BoostFab wrote:MDF is fine for home audio since you don't move them around much. But for live sound and mobile dj's, moving a truck load of horn cabs made from MDF can be tiresome from all the weight.loudsubz wrote:I have never had an issue with MDF. I used to always build sub boxes, and even built a few for the marine enviroment and with the moisture I havn't run into any issues. I do give it a thumbs down because if you do drop it and its a hard fall it can split unlike plywood which has a little give, but for the most part I really had no issues with MDF.
Re: Birch vs MDF
I think for my garage sub, I'll need plywood or BB. With the summer humidity in the NE and the cars the garage in the winter, all the snow melting.......
I wish OSB was workable LOL
Re: Birch vs MDF
I'm prepping to build the THT LP. I only seem to be able to find 5 X 5 sheets of BB. Since the outer panels of the LP are 72", they won't work unless I join them with a tongue-and-groove. (Not my first preference)
Any ideas?
						Any ideas?
