Winter NAMM 2011
Re: Winter NAMM 2011
They're supposed to send them to me.
- Dave Non-Zero
I've not even caught up with upgrading to the 3012ho yet. Ah well, it will be about 2015 before they get over this side of the pond so I'm not holding my breath.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
LelandCrooks wrote: Yes, it's the legendary 3010ho and 3010lf. For release later this year.
Dr250 3010ho with dual nsd's anyone?
Just in time for my next build.LelandCrooks wrote:Yes, it's the legendary 3010ho and 3010lf. For release later this year.
el_ingeniero
Now for a 3008ho, and we might have something even better than a D-Pro 8 for our DR200s ...LelandCrooks wrote:Yes, it's the legendary 3010ho and 3010lf. For release later this year.
Hehehe I was thinking that Bill's probably already hard at work designing an OT10.SeisTres wrote:LelandCrooks wrote: Yes, it's the legendary 3010ho and 3010lf. For release later this year.![]()
Albert Einstein
Albert Einstein
Could you please post the specs of the 3010lf if you are allowed and if they are not listed anywhere else? Since I saw this pic, I'll be holding off on the dayton and see how the 3010lf models in my t39's (hence the request). But who knows, if the price difference is big enough, I might still decide to get one of the daytons. Even if doesn't really turn out well, I can always just build a TAT or another TT withLelandCrooks wrote:They're supposed to send them to me.
Basket is square instead of round specifically for T39 slims I see.LelandCrooks wrote:legendary ... 3010lf.
Don't wait for them. It might be a year. Contractual stuff with OEMs.
Preliminary 3010LF specs...
http://www.eminence.com/speakers/speake ... ite_3010LF
It'd be interesting to see what Bill's horns can squeeze out of it.
Re: Preliminary 3010LF specs...
Thanks for the heads up, i had browsed around their site a while ago and nothing has been posted. With the specs provided, it models extremely well in the slimmer t39's. the response is quite flat through out the passband while the max spl is only a a couple of db's behind the 3012. I'm thinking the 14" t39's will be simply perfect for this driver.Radian wrote:http://www.eminence.com/speakers/speake ... ite_3010LF
Thanks for the heads up, i had browsed around their site a while ago and nothing had been posted. With the specs provided, it models extremely well in the slimmer t39's. the response is quite flat through out the passband while the max spl is only a a couple of db's behind the 3012. I'm thinking the 14" t39's will be simply perfect for this driver.Radian wrote:http://www.eminence.com/speakers/speake ... ite_3010LF
EDIT: yes, i only modeled the t39, as imo, the only two subs that matter are the t39 and the t60; everything else is extraneous.
I wonder how much those are going to be then, I'd quite like a stack of slim 39s.
I expect the price to be just about the same as 3012LF. Motor appears similar, weight will be about the same.
I can't wait to see how much you could get out of a 24" Tuba24 dual loaded with these... would it work with the current design? or would it need a full rebuild? I'm excited.
