Anyone using XTI's DSP for EQ at gigs?
I have a little rack bag with the XTI1000 wired to an Alesis MultiMix 8 USB that lives in the pouch. This is my band's practice and small bar gig when the StudioLive and amp rack is just too much. Plug in power, roll out the 30' 8ch snake lead and 30' NL4 speaker lead from the back of the bag, and ready to roll. Might be a decent solution for an acoustic PA with Jack10s and only a few line requirements.
Anyways, should one really have a Graphic EQ in addition to the DSP in the Crowns? It seems as though the Crowns can do PEQ on the input and output signals. So I have customized the output for speakers (decent but not great) but then I was thinking about using the input PEQ and laptop at gigs for ringing out the system, notching naughty freqs, and warming up the tone for the room.
Thoughts?
XTI DSP
Re: XTI DSP
go ahead and pick yourself a decent 31 band (used is fine), it will make things easier on you in a gig setting for sure.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
1x bastard XF208
Re: XTI DSP
+1sine143 wrote:go ahead and pick yourself a decent 31 band (used is fine), it will make things easier on you in a gig setting for sure.
The dsp is good for set it and forget it type of work.
4 20" T39(built)
2 WH8(built)
3 WH10(own)
4 DR200(own)
1 Jack 12(built)
SAC 24 Channel Mixer
SAW STUDIO Recording
Re: XTI DSP
I know, I know, I should just get a 31 band. I was trying to avoid getting a bigger rack. These soft-sided ones are nice but only seem to come in 2 and 3 space sizes. I was hoping to use the 3rd space for a power conditioner or handheld wireless receivers. Maybe I should just give up on my thought of a "backseat sized" P.A.
Thanks!
Matt
Thanks!
Matt
Re: XTI DSP
eh, build yourself a little plywood 4 RU rack, make a cover for it, it will be tiny enough haha.
1x bastard XF208
1x bastard XF208
Re: XTI DSP
Check out Rondo Music. They have 2,4,6 and 8U rack bags, and each is under US$60!
I have ordered rack cases from them, and they are of decent quality. Just watch their shipping charges.
