Crown XLS 2500 vs RMX 2450 for 2 T48s
Yes I know, apples to oranges..For powering my pair of T48s, I am trying to decide what is a better option. I tried out the RMX 2450 twice and it is very powerful with good headroom. Would this be the case with the new XLS? How about being a bass-friendly amp? I've read some amps don't produce bass as good as others.
All the good deals on used RMXs on Craigslist are killed by the shipping costs, and for 25% more, I can have a brand new Crown.
2 T48's 36" wide 3015LF loaded
- camrynekai
Re: Crown XLS 2500 vs RMX 2450 for 2 T48s
I just got 4 of the XLS2500's...haven't ran them for sub duty only for monitor duty so far. They seem like OK amps, only thing I dont like is the X-over/HP filter...your limited to 50Hz
that might be a indication that they might not be suited for sub duty.
Facebook Page
More Bass then Fitzmaurice??? Click here
My herd of T48's
Cabs built
14- 24" T48's 3015LF's
6- OTop 2X12's W/Straight array's
4- OTop 12's W/melded array's
2- OTop 12's W/Straight array's
2- 29" Sla Pro's
1- Auto tuba ITW
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
Since you are comparing to the QSC, then you obviously don't need processing - thus the XLS shortcomings in that area don't matter.
I'm using an XLS 1000 in bridge mode to run my subs and they work like a champ. Other considerations:
The Crown is only 10 pounds.
The new Crown has a 3 yr warranty. The used QSC probably has none.
Also, if you are just running 2 T48s, no reason not the run the XLS1000 in bridged mode. Unlike the older XLS models, the Drivecores are rated to run bridged at 4 ohms (each channel can go to 2 ohms). Plus, you'll save a ton of cash.
So, between the QSC and Crown...
Crown...no brainer.
Crown...no brainer.
Yes no processing needed on amp (2496 in sig.) I tried my XLS 602 in bridged mono this past Sat. 2 T48s were 5 ohms. Amp is rated for 4 ohms bridged mono. It didn't fare any better than both T48s on 1 channel nor them each on their own. I was dissappointed based on the wattage claims in 4 ohm b-m. 5 ohms shouldn't have been much less. Either way, I need good headroom so the XLS 2500 would be the option over the 1000.
The 602 didn't work well because it is not designed to run a 4 ohm load bridged.djengineer wrote:Yes no processing needed on amp (2496 in sig.) I tried my XLS 602 in bridged mono this past Sat. 2 T48s were 5 ohms. Amp is rated for 4 ohms bridged mono. It didn't fare any better than both T48s on 1 channel nor them each on their own. I was dissappointed based on the wattage claims in 4 ohm b-m. 5 ohms shouldn't have been much less. Either way, I need good headroom so the XLS 2500 would be the option over the 1000.
http://www.crownaudio.com/amp_htm/xls.htm
Lucky that you didn't blow it up.
The XLS1000 is designed to run a 4ohm load bridged. It puts out 1100 watts - 2-T48s only need 900 running at max so there is plenty of headroom......In fact, the XLS1000 bridged is more power than the 2500 running one per side - 550 watts per speaker vs. 440.
http://www.crownaudio.com/amp_htm/xls_drivecore.htm
Obviously, if you bridge the 2500 it is way more power.....but overkill for no reason. You can get the XLS 1000 for $300. I like this series of amps and either one will work - I just like saving money.
Yeah as soon as I saw slight clipping, I switched them on their own channel. The manual gave (1600w?) At 4 ohms b-m. So I was tricked. I agree on the 2500 being overkill, esp if I don't plan on building more cabs anytime soon. I ordered the 1000 and will have it for Thurs night gig. I will surely report my experiences. Thanks all for input. Happy Holidays!
- camrynekai
Ohhhhh boy...you wouldn't want to hear what I power my T48's withBruce Weldy wrote:Obviously, if you bridge the 2500 it is way more power.....but overkill for no reason.
Facebook Page
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
- Dave Non-Zero
Um, I do!!!
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
- camrynekai
well...ummm...a XTI6000
just cant run that HP to low or bad things WILL happen. I have quite a few gigs under the belt with this setup and I just love it. I can run all 8 of my T48's with one amp and not break a sweat...HP @ 45 the T48's will take all that the XTI6000 has to offer.
Facebook Page
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
man.... 45 just seems too high for an 8 stack.... I'd be thinking you could push low 30s, if limited to 60ish or below. We discussed using Itech HDs for t48s.... a man can dream.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
1x bastard XF208
- camrynekai
I use 45 for war volume and 37 for everything else. Low 30's....no way, I'm to chicken shit to do that...BTW did I mention I hate limiters. The XTI6000 is a Itech with a few caps missing from the power supply...whole different beast then the rest of the XTI series.sine143 wrote:man.... 45 just seems too high for an 8 stack.... I'd be thinking you could push low 30s, if limited to 60ish or below. We discussed using Itech HDs for t48s.... a man can dream.
Facebook Page
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
- Dave Non-Zero
Run all 8 from one amp? I may have to look into that. It's in the future tho, can't afford a 4000, never mind a 6000.
I'm going to be doing more events next year that require 6-8 of my t48 so I need a solution that won't break my back or bank.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
- camrynekai
Dave, If it wasn't for the $400 Crown rebate I wouldn't own one either...I will say that the XTI saves me over 65lb's from my amp rack and 2 less NL4's that need to be ran
Facebook Page
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
- Dave Non-Zero
Nice! But what is this rebate of which you speak!?! 'tis some magical manna from heaven around the witching hour?
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
