OTop 12 Build (Hit Major Snag)
tdogg
Re: OTop 12 Build
#16 Post by tdogg »
Bill Fitzmaurice wrote:
Dave Non-Zero wrote:in 4hours i'd probably get the baffle and spacer ring done. :(
In a four hour period I spend one cumulative hour trying to find the pencil I put down thirty seconds before. :noob:
Memory is the second thing to go.
I forget what the first is.
i have the same problem, so i buy large quantities of pencils and scatter them throughout my shop and tool boxes. i do the same with guitar picks at the practice space.
Jack 112 deltalite 2512 x2
SeisTres
Re: OTop 12 Build
#17 Post by SeisTres »
tdogg wrote: i have the same problem, so i buy large quantities of pencils and scatter them throughout my shop and tool boxes. i do the same with guitar picks at the practice space.
:clap:
This is what I do, too! Good thing I only went through 12 dozens of picks in a whole year :)
BoostFab
Re: OTop 12 Build
#18 Post by BoostFab »
doncolga wrote:Ok...this is my official start to my Otop 12's. Just need one more sheet of BB and my two kits. How many hours would you all guestimate this would likely take? I have no bookings next weekend, so I'd really like to knock out the pair then. Should that be doable over a Friday-Sunday?
after an hour of cutting, i'm ready to assemble. and it's my first time with the ot12.
you should knock out two ot12 in a weekend
Bill Fitzmaurice wrote:In a four hour period I spend one cumulative hour trying to find the pencil I put down thirty seconds before. :noob:
Didn't you tuck the pencil on your right ear! LOL
David Sample
Re: OTop 12 Build
#19 Post by David Sample »
Dudes................. common sense and logic says that if you REALLY want to stop searching for your pencil, just stick it somewhere so uncomfortable that you CAN'T forget where you put it!!! :noob: 8) :wink:
Then you might also be inclined to NOT put that nasty thing in your mouth!!!!!!!!!!! :shock: :shock: :shock:
doncolga
Re: OTop 12 Build
#20 Post by doncolga »
David Sample wrote:Dudes................. common sense and logic says that if you REALLY want to stop searching for your pencil, just stick it somewhere so uncomfortable that you CAN'T forget where you put it!!! :noob: 8) :wink:
There's a sticky on subwoofer placement...maybe pencil placement strategies will be included in the future plans.
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
Re: OTop 12 Build
#21 Post by AntonZ »
That's what I do (pencil is just about the only thing that I don't need to search for in the workshop). Learned to do this from my father. I already see my kids (5 and 7yo) do the same occasionally. Could become a rather annoying problem when working with PU glue though. Then you'd know where the pencil is, it's always within reach but it won't detach :owned:
I can see myself moving my head over sheets of ply to draw cut lines, that would be real silly :fruit:
jswingchun
Re: OTop 12 Build
#22 Post by jswingchun »
$1.99 at Home Depot (obviously) never lose your pencil.
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
doncolga
Re: OTop 12 Build (now Jack 112)
#23 Post by doncolga »
OK...change of plans. I'm very likely going to be changing this OT12 build to a set of Jack 112's. I do need a set of great full rangers for smaller jobs, then being able to use them with subs for large jobs, I'm sure they'll do great. Once I do build the OT12's, the Jacks should make great monitors. In a way, the build looks a little easier too. Comments or suggestions on that line of thought?
Thanks!
Donny
Donny Collins
mems
Re: OTop 12 Build (Now Jack 12 Build)
#24 Post by mems »
Sounds good to me. That s how I am going. 3012Ho's and for this gig coming up a single T30 3012lf. Soon to be two T30's of the same. I can' wait to hear em Saturday when it all set up and ready to go. Should sound amazing.
doncolga
#25 Post by doncolga »
mems wrote:Sounds good to me. That s how I am going. 3012Ho's and for this gig coming up a single T30 3012lf. Soon to be two T30's of the same. I can' wait to hear em Saturday when it all set up and ready to go. Should sound amazing.
Very cool. I'm picking up BB as I write this and hope to find some time this weekend to work on the boxes, along with a TON of other stuff I have to do. My drivers and other parts will be in on Monday and later next week, so with any luck I'll be able to use them next Saturday...just have to see how it goes. Right now the Jacks just make more sense as they can do double duty as tops and full range for little jobs, then they'll be monitors when I do have Otops.
Donny Collins
CoronaOperator
#26 Post by CoronaOperator »
http://www.staples.com/Dixon-3-1-2-Golf ... plesSearch
I just checked and I have 7 boxes of these strategically placed in various areas at my work. Rip the top of the box off and if you precut some paper about 3" x 4", you can stick a stack of paper it the back of the box too.
I couldn't live without them. lol
doncolga
#27 Post by doncolga »
This is a question about the Jack baffle, driver ring and T-nuts. Maybe I'm missing something in the plans, but shouldn't the driver ring be placed on the baffle right after the baffle is cut out, along with the driver holes and T-nuts placed? I'm a little concerned about placement of the driver holes and T-nuts as it looks like the T-nuts could be at join lines with the ducts and horn braces, depending on how you place the holes...am I just overlooking something?
Thanks!
Donny
Donny Collins
#28 Post by Bill Fitzmaurice »
doncolga wrote:..am I just overlooking something?
The instruction to use screws? :noob:
doncolga
#29 Post by doncolga »
So no t-nuts to bolt on the driver?...just screw them in?
Donny Collins
mems
#30 Post by mems »
That's correct. I made that mistake as well. Just screw them in using locking washers that are small enough to ensure the screw head wont go through them.
