I'm looking for cheapest option for powering and eq my little system (2T39, 2OT12).
I have found that this eq has subwoofer out and low cut filter.
But, there is lack of information in the manual.
Im interested if anyone has used this unit?
What is low pass frequency?
If i set subwoofer out to 120hz, does regular outputs play 120Hz up, or full range?
Behringer FBQ1502 anybody used ?
Omnitop 12 (Kappa12 - melded piezo) - 2
Titan39 (B&C 12BG100) - 1
https://www.facebook.com/djserviskula?fref=ts
- Chris_Allen
Re: Behringer FBQ1502 anybody used ?
I own one and do recall it having a sub out. However, despite actually liking Behringer gear, this is a turkey - signal bleed is terrible and the Q between frequency bands sounds inconsistent.
- BrentEvans
Also, the "sub out" is a 12 db/oct crossover (despite what some of the manuals say)... very poor choice. I have one too.
If you're after cheap... do the Behringer cx2310 crossover in mono 3-way (gives you a low pass for the subs, you run the subs as "mids" and the "sub out" becomes your sub filter (24db/oct.. much better) and the FBQ3102...
of course by the time you get both of those, you could add a Franklin or so and have a DCX2496... and have everything you need, including limiters, crossovers, delays, PEQ, etc.
