The build days are not consistent but thought I would lay out how it started and is progressing. I have been racing against the weather as I don't have a heated garage, this is never a good thing to do with these builds. Decided to go BB on the outside except panel 10 and acuaro for the guts.
Day 1
Got 2 sheets 5x5 BB and ripped them down with a guide board system. Made all the lines per the plan and made access hole for driver. Best access hole cut yet! I used BB to draw lines with full intention of using acuaro ply for inside panels, the thickness is a little different. More time should have been spent on the ripping cuts too as the they were a bit off/wobbly.
Day 2
After spending way too long trying to find some decent 8x4 sheets at Menards, I had to settle by picking the 2 best out of the maybe pile. What a workout, moved a dozen sheet twice. At least I got the "pump" going as Arnie says it
Had a friend of mine rip 48"x26" panels as he is a cabinet maker. What a life saver as it went quick, effortless and precise cuts. Brought them all home and got panels 1 and 2 up. Panel 1 is 1/2" too short according to the lines on side panel, panel 6 will have to make up the difference, need to measure these things 1st instead of going by plan...even on 1st panel.
Day 3
Able to get panels 3-5 up with a few known issues at the time, mainly a boat load of time spent on panel 4. Besides my newly acquired tablesaw is a POS and may possibly have a personal grudge against me. Reverting to guide board and 14.4 volt skill saw. Joint 2&4 are needing some PL love to fill the angle being open a bit. Also the tip at joint 3&4 is a little short but can't see that being a huge issue
Day 4
Panel 6 and braces go up with little issue. I am using lower grade 1/2" ply for bracing, had it sitting around the garage. Then came panel 7. This was a nightmare, just could not get the angles right, something was always wrong. Panel ended up a bit short at the top of the mouth. PL fills the angle gaps again. My belt sander made all the difference in the world on this. It was time to drink when this was done
Day 5
Panel 8 was a breeze except the bracing. I installed what I thought was a nice tight fit but not too tight for the braces. I had a ton of issues getting panel 9 in. Day 5 started to haunt me on day 6. Put wire #1 in to the mouth.
Day 6
When I tried to put in panel 10 the corner was about 1/2" off at the "top" where they meet. It turned out the braces pushed everything out a little. 3-5 clamps helped gradually pull the corner in, brad nailed everything together at the 8&9 corner but left my clamps on for a couple days. Got my wire #2 in to the last reflector area. Panel 10 braced and ready to go.
By luck I learned a great technique for finding air leaks prior to closing up the horn. Can't remember why but had a bright flashlight looking down some of the empty chambers and noticed I could see it in the adjacent part of the throat, UH OH. It was mainly on the cheated angles. Well a lot of choice words and lots of PL later I am glad I caught those issues. I just caulked the lines with PL and my finger until no light came through anymore. Now I am second guessing my other builds, however I was unable to ever find a leak in any of them doing the stethoscope method when they were done.
Day 7
Put in last panel and 1st reflector. Caulked the reflector with PL as light came through again.
I painted the last part the throat with some left over dark deck paint. Unfortunately even though I thought about it I started painting the wrong side of the finishing side panel...doooh. So I guess I will be finishing the outside of the built too. Though I would wait until it was done to decide if that was going to happen.
Day 8
Put in last reflector, last throat braces in. Painted the mouth and braces for the mouth. Hopefully I will get my package from LeLand tomorrow so I have my casters and handle holes to cut out. I have a multi tool so cutting them out after should not be an issue.
Getting close to done! I am on the home stretch, usually the hardest part. Prelims are telling me some major clamping will be in order to make this sucker close up right. I will try to get some pics up soon, but it is a little late for me to at the moment. Hopefully some one can learn from the pitfalls I have encountered.
