first drs
first drs
Well I started on my Dr30s. Thank God I found a guy who is a great carpenter. We decided to work with spruce before went on to work with the more expensive birch. I hope we are doing justice to Bill. At first it was to understand the diagrams but we got the the hang of it.
Re: first drs
very cool. dr300's? what kind of gigs are you using them for?
Jack 112 deltalite 2512 x2
Re: first drs
tdogg wrote: dr300's
Look at the SIZE of those monsters! Those blades of grass look TINY in comparison.
J/K.
Looking good, hope to hear the reviews soon
Re: first drs
I will be mainly doing church events. Crowds around 10 to 15000. I hope they work for this kind of crowd.
- Harley
Re: first drs
Bit of an overkill for just 10 people I would have thoughtjesuchete wrote:I will be mainly doing church events. Crowds around 10 to 15000. I hope they work for this kind of crowd.
- Drey Chennells
Re: first drs
Jesuchete, I'm sure these will be most impressive for you. I mean this well but, I highly recommend you take any "hope" out of the equation and take the time to calculate all the parameters involved in covering that many people. I wouldn't want to guess on any aspect of a job that size, you know what I mean?jesuchete wrote:I will be mainly doing church events. Crowds around 10 to 15000. I hope they work for this kind of crowd.
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
InfraCoustik
- Doug Hart
Re: first drs
]Drey Chennells wrote:Jesuchete, I'm sure these will be most impressive for you. I mean this well but, I highly recommend you take any "hope" out of the equation and take the time to calculate all the parameters involved in covering that many people. I wouldn't want to guess on any aspect of a job that size, you know what I mean?
+1
Don't leave anything to chance when doing something that takes that much time and costs that much money.
To cover 10k-15k people, you will likely need 16-24 of those (depending on desired volume) and just as many Titans. That's a lot of money and time to leave ANY guesswork in there.
Doug Hart, Owner
dB Pro Audio
Authorized Builder
http://www.hartdesignsetc.com
dB Pro Audio
Authorized Builder
- Chris_Allen
Re: first drs
You also need to factor how loud you want it. You might not need war volume for all those people.Doug Hart wrote:To cover 10k-15k people, you will likely need 16-24 of those (depending on desired volume) and just as many Titans. That's a lot of money and time to leave ANY guesswork in there.
The balance triangle in this example might be:
.......................... number of cabs.............................................
.......crowd density ----------- distance for required freq@SPL.
It's early in the morning, so my brain doesn't have the capacity to fully evaluate this model.
What I am trying to show is, a reduction in distance for required frequency@SPL will increase crowd density for the same number of cabs.
An increase in the number of cabs for the same means either a higher crowd density or a greater distance for required frequency@SPL.
If you need more crowd, you either increase the number of cabs or decrease your SPL for a given distance. etc
(This is based on an assumption that a larger array has more coverage)
I can already see cracks in this - so feel free to pull it to pieces, constructively of course
Re: first drs
whats your current system?
Re: first drs
This is my first large system. Thanks guys for all the help. I mainly work with churches in africa. I am probably the first to build these in my country. I am currently in canada and I need a supplier for drivers and parts. I am not sure about express shipping to canada ,I won`t be paying customs but have to deal with an hst tax 13%.yikes. check this crowd out.
http://www.youtube.com/watch?v=dBWOCMhJ0CA.The crowd was estimated at over 1 million people. I don`t know how they managed relay all the speakers. I know these guys had a system especially built for them. It takes them weeks to setup. I won`t be anywhere near that size yet!!!!!!!!!!
Re: first drs
Thanks Tom here is where I am.
Re: first drs
Man those things are big. The only cab I haven't built.
Re: first drs
Yeah they are huge. I am thinking I need to do a jack or a smaller dr or the smaller venues. I am wondering if the jack would be better than a say a dr20 or dr25. Cost of the Dr300 right now is at about 450. I have smaller venues with about 1000 people how many jacks would I need.
