How and where to I test for voltage? I'm about to finish my first Titan 48 build.
Thanks!
Donny
Testing Voltage
Testing Voltage
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
Re: Testing Voltage
I gonna assume you mean amplifier output voltage.
Set a multimeter to AC and scale appropriately.
You can measure voltage from the start to the end of the system -
One probe on + one on - ( or red/black).
At LINE LEVEL; it ranges from .775V and up ( some devices can produce 2 - 10V ).
An amp often expects about 1.5V ( check specs ) and it brings that up to a level that drives speakers. Usually at least 20x.
( Measure across the speaker output jacks of the amp - no speakers attached )
See multimeter tutorial links posted in this thread
http://billfitzmaurice.info/forum/viewt ... =7&t=12114&
Syd
Syd
Re: Testing Voltage
So what should I be looking for when I measure voltage...I'm not seeing how this fits into the big picture...Sydney wrote:I gonna assume you mean amplifier output voltage.
Syd
Donny Collins
Re: Testing Voltage
Syd set me straight when I was testing my XTi 1000...
I had connected banana binding posts to my screw connector outputs. That's what I used to set my limiters - red to red, black to black, test for AC voltage and put the limiters at -3, -6, or -12dB to get the voltage under the threshold. Use a test tone generator or Audacity.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
Re: Testing Voltage
You calculate the maximum voltage that you want to feed your speakers.So what should I be looking for when I measure voltage...I'm not seeing how this fits into the big picture...
You set a limiter so that regardless of how much voltage is fed into the inputs of the limiter; the limiter will not pass on the increased voltage to the amp to be amplified.
The sound reinforcement handbook By Gary D. Davis, Gary Davis, Ralph Jones
p 172 11.7 Gain staging and Gain structure
p 271 14.3.2 How Compressor/Limiters work
p 37 4.3 Manipulating Dynamic Range in a Practical Sound System
http://www.proaudiosystems.co.uk/docs/h ... llers..pdf
http://www.prosoundweb.com/article/how_ ... structure/
http://www.soundonsound.com/sos/oct08/a ... 1008_5.htm
http://www.communitypro.com/files/liter ... C_TECH.pdf
http://www.communitypro.com/files/liter ... V_TECH.pdf
Syd
