I aim to please.Doug Hart wrote:Thanks a lot Brent... I just drooled all over my keyboard
WOW! Check out the new amps from PE!
- BrentEvans
Re: WOW! Check out the new amps from PE!
- Doug Hart
Brent:
PM sent to you
PM sent to you
Doug Hart, Owner
dB Pro Audio
Authorized Builder
http://www.hartdesignsetc.com
dB Pro Audio
Authorized Builder
- kdchandler
BTW, these amps are also all over eBay if you search for Tripath. Some of them come with the volume encoder, too
4 DR200, 6 TLAH (semi-pro)
4 T39 (20" BP102), 2 TT ( 1 ea W8-740C, HL10A)
2 Wedgehorn 6, 1 Wedgehorn 10
- Doug Hart
Are Tripath and sure related?
Doug Hart, Owner
dB Pro Audio
Authorized Builder
dB Pro Audio
Authorized Builder
- BrentEvans
Recieved, replied.Doug Hart wrote:Brent:
PM sent to you
CafSentryGnome
Have a look at this site. www.class-d.com and click on Mosfets / Modules.
Doug Hart wrote:I wonder if you have to use their power supply?
That drives up the cost quite a bit.
(EDIT) also, since they are 4 ohm capable, can they be bridged with an 8 ohm speaker?
From 12 to 32v means you could also power from batteries!, a couple of 18ah motorcyle batteries for 24v maybe?
- Rune Bivrin
Contrary to what you might me led to believe by the site name, these modules are NOT class d, they're regular class AB amps, which means a couple of things:tcorder wrote:Have a look at this site. http://www.class-d.com and click on Mosfets / Modules.
- They're not nearly as efficient.
- They will require a big heat sink.
- They will require a bigger and heavier power supply.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
I was referring to the size and price of the amp modules.
- Rune Bivrin
Sure, but factor in the required heat sinks and larger power supplies, and it's not so small or cheap any more.tcorder wrote:I was referring to the size and price of the amp modules.
In build order:
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
- Doug Hart
Initial tests of the Sure 8 watt/ch PE amp not too bad.
30hz test tone, I was getting about 3.5 watts out of it.
I was driving one 6 ohm speaker. Loud enough for my workshop.
Fairly easy to overdrive the inputs tho.
I was using a 12v power supply. More power may yield better results.
Haven't had time to test the 100w amp yet.
Doug Hart, Owner
dB Pro Audio
Authorized Builder
dB Pro Audio
Authorized Builder
Oowee! I'm awaitin' on your results. Like, do the work better with 24 volts? Do they sound good? etc, etc.
Thanks!
Thanks!
- Doug Hart
I don't have a 24v power supply.Tom Smit wrote:Like, do the work better with 24 volts?
I wonder if I can wire two identical 12v wall warts together in such a way to get 24v... without blowing anything up of course.
Doug Hart, Owner
dB Pro Audio
Authorized Builder
dB Pro Audio
Authorized Builder
NO. Oops, I'm yelling.
Eight C or D cell batteries all in a row will get you to twenty-four volts. Or, two car batteries in series will get you there as well.
