Best option for 2 Jack 110 (Deltalite 2510) and 1 Titan 39
Is this amp OK?
mino00
#1 Post by mino00 »
Which is the best option Amp for 2 Jack 110 (Deltalite 2510) and 1 Titan 39 load with Kappalite 3012lf ?
2 XTI 1000
1 XTI 2000
Or any other recomended amps ? your input greatly appreciated ?
bzb
Re: Best option for 2 Jack 110 (Deltalite 2510) and 1 Titan
#2 Post by bzb »
One vote for the XTi 2000 here. For outdoor gigs, I will be running 4 T39s 3012LF on two channels of an XTi 2000, and 4 OT112s 2512 on 2 channels of an XTi 1000.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
jswingchun
#3 Post by jswingchun »
bzb wrote:One vote for the XTi 2000 here. For outdoor gigs, I will be running 4 T39s 3012LF on two channels of an XTi 2000, and 4 OT112s 2512 on 2 channels of an XTi 1000.
+1
You can run it all off two channels of the XTi2000 for now and if you ever want a bigger system, double your cabs and add an XTi1000 for the tops and run the subs off the XTi2000. That's exactly what I am going to do. My system is now exactly half of what bzb's system is, eventually will be the same as his. :D
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
jcmbowman
#4 Post by jcmbowman »
A couple drawbacks to running a single amp:
1) you have no choice but to run mono. If you never plan on running stereo, I guess that's fine.
2) You have no failover if the amp chokes.
Not that either of these are deal-killers, just something to be aware of.
4 DR250s
4 Tuba36s @ 30" wide
2 ATs
mino00
#5 Post by mino00 »
How about 2 QSC gx5 ?
#6 Post by Bruce Weldy »
1 will work. 500 watts per side at 8 ohms and 700 at 4 ohm. Run the two Jacks at 350 ea. on one channel. Run the T39 at 500 watts on the other. However, if you want to add another sub, you'll need another amp to get full power......that said, I had an amp failure and had to run 2 T39s off one side of a GX5 and it was plenty!
mino00
#7 Post by mino00 »
Thanks you
I just got a good deal on 2 GX5 , So I bough both of it for the future if I decide to add another T39.Therefore I can run one amp for the top ( stereo) and another for the sub .
#8 Post by Bruce Weldy »
Before I got Crowns, we used the GX5s to run subs on one amp. On the other, ran 2-OT12s on one channel and monitors on the other. Plenty of power. But, they can't be bridged....so, if you double you sub count, you'll need more amps.
