 my wife has just started a music promotions business and wants to use my PA. iv just pulled it all apart to build new cabs for it as its just a quad of 15" reflex - 2 full range and 2 sub. its going to be used primarily for Psytrance+ house+ some RNB/DNB when i use it, and when she wants it itll be used for rock and punk metal.. iv just ordered a pair of yamaha 3103(quite old but in REALLY good nick) 12" drivers to use as full range midbass type drivers, iv settled on a pair of 6" and a horn tweeter for my high end >400hz, and i have a 10" on either side for 80hz>200hz. im thinking to use all four of my 15" woofers each in a tuba30 and thinking of an onmitop12 for the yamaha's.
  my wife has just started a music promotions business and wants to use my PA. iv just pulled it all apart to build new cabs for it as its just a quad of 15" reflex - 2 full range and 2 sub. its going to be used primarily for Psytrance+ house+ some RNB/DNB when i use it, and when she wants it itll be used for rock and punk metal.. iv just ordered a pair of yamaha 3103(quite old but in REALLY good nick) 12" drivers to use as full range midbass type drivers, iv settled on a pair of 6" and a horn tweeter for my high end >400hz, and i have a 10" on either side for 80hz>200hz. im thinking to use all four of my 15" woofers each in a tuba30 and thinking of an onmitop12 for the yamaha's.is this a good idea??
if the omni tops can be used with the yamahas and eliminate the need for the tens, id much rather do that as the tens sound pretty crappy above 200hz. my reason for wanting to build the tuba 30 (x4) is because at some point i will be able to afford some decent drivers to put in the cabs, and so starting with a decent box and then updating later on makes sense in my eyes. and also the fact that it will primarily be used for psytrance is the underlying factor, oh and outside(bush/paddock) to a crowd of 10>400 at this point.
thanks in advance for your help and ideas =)
