Amps for Jack & titan 39
Is this amp OK?
mino00
#1 Post by mino00 »
Hello
Newbie need advice on amps, have decided to build 2 Jack 110 (Deltalite 2510) and 1 Titan 39 load with Kappalite 3012lf, how much power do I need to get the most from these speakers ?, what are the best amps for the money?, will one amp do it all? or should I use 2 amps? Which plate amp suitable for the titan 39 . I rather use a plate amp for the t39 and an amp for the Jacks
Thanks
sine143
Re: Amps for Jack & titan 39
#2 Post by sine143 »
why a plate amp on the T39? What er you oging to be using this rig for?
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
mino00
#3 Post by mino00 »
Hello sine143
Normally I use this rid for karaoke & general listen to pre recorded music , some time I use for the pool party that I will crank up the Titan
Thanks
Israel
#4 Post by Israel »
crown xls series are on end of line sale you can get one for little , use one side for tops the other for tops, you can buy 2 if you want
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
mino00
#5 Post by mino00 »
Hello
Which model crown xls would be sufficient ? , If I need more head room for future which would be best ?
Thanks
sine143
#6 Post by sine143 »
crown xti 1000 can cover you for both tops and sub.
Also, look into lelands powered options over at speaker hardware.
1x bastard XF208
mino00
#7 Post by mino00 »
Hello
Would Crown XTI 2000 power amp good enough ? one channel for the Jack and one for the Titan .
Thanks
sine143
#8 Post by sine143 »
the 1000 would be good enough for the job probably. Using 1 T39 is going to be where you are limited, 8 ohm load and such. the 2000 will definitely do the job.
Why only 1 T39? How wide are you going to build it?
1x bastard XF208
mino00
#9 Post by mino00 »
Hello
20" wide
Thanks
tdogg
#10 Post by tdogg »
the titan with a 3012lf is limited to 450 watts and the two jacks can only handle about 400-500 together, so a 500w x2 amp is perfect. skip the plate amp.
Jack 112 deltalite 2512 x2
mino00
#11 Post by mino00 »
How about QSC GX5
GX Series
SPECIFICATIONS GX5
8 ohms / 1 kHz (single channels driven) 350 W 600 W
4 ohms / 1 kHz (single channels driven) 500 W 850 W
Thanks
sine143
#12 Post by sine143 »
tdogg wrote:the titan with a 3012lf is limited to 450 watts and the two jacks can only handle about 400-500 together, so a 500w x2 amp is perfect. skip the plate amp.
the problem is that the jacks will be 4 ohms, the single T39 will be 8.
1x bastard XF208
tdogg
#13 Post by tdogg »
cant the crown amps handle an unbalanced load?
sine143
#14 Post by sine143 »
yeah, but you wont find many amps that throw 500 watts at 4 AND 8 ohms hehe.
1x bastard XF208
#15 Post by Bruce Weldy »
sine143 wrote:yeah, but you wont find many amps that throw 500 watts at 4 AND 8 ohms hehe.
Actually the GX5 will work fine. It runs 500 watts at 8ohms and 700 at 4ohms. The Titan on one side gets 500 and the Jacks share 700.. The numbers that he posted were for single channel being driven...he's going to drive them both, so those numbers don't matter.
I've run my Titans and OTops with GX5s before I got the Crowns....they run just fine.
