That would be Brill. The Delta Pro 12 should be similar, - but heavier of course.Chris_Allen wrote:Afaik, the OT12's were measured with the 2512. I do have charts for the 3012HO which I need to get sampled.
Introducing SPL Chart
Re: Introducing SPL Chart
I live the smell of birch ply in the mornings... Smells like... Victory!
Mystery over. The 3012HO chart is now included in the updated plans.Chris_Allen wrote:Afaik, the OT12's were measured with the 2512. I do have charts for the 3012HO which I need to get sampled.
Is your chart for the new phase plugged OT12?
- Chris_Allen
The existing charts are for the old design but are scheduled to be updated.
any chance you could model a O15tb/wb against a fEARful 15/6?
Jack 112 deltalite 2512 x2
Do you have a measured chart for the 15/6?tdogg wrote:any chance you could model a O15tb/wb against a fEARful 15/6?
i dont. ill ask around on Talkbass to see if one existsBill Fitzmaurice wrote:Do you have a measured chart for the 15/6?tdogg wrote:any chance you could model a O15tb/wb against a fEARful 15/6?
Maybe not exactly what you're looking for, but I compared the the woofer only sections of both using the exact same 3015LF driver. Outside, ground plane.tdogg wrote:any chance you could model a O15tb/wb against a fEARful 15/6?
Omni has a 3-4 dB advantage at 40-50 Hz, Ff has 3-4 dB advantage at 80-100 Hz.
I've built another O15TB to do so some revisions, mainly to the midhorn/tweeter. I'm not getting the nulls at 80-100Hz and 315Hz like you are. I'm also not getting that 50Hz bump, and the LF corner is at 40 Hz. I'm using a 2515 woofer for the testing. In theory the 3015LF should be almost identical, so I'm still puzzled with your result.WB wrote: Omni has a 3-4 dB advantage at 40-50 Hz, Ff has 3-4 dB advantage at 80-100 Hz.
- Harley
Correct. That chart is the one for driver-only. No tweeters of any type.Bruce Weldy wrote:I'm assuming no piezos or horn on that J110?
Harley, was your point that the W10 has better response than the J110 across the board? Are you thinking of switching?
- Harley
It''s not for me - I have a client who wants both a W10 monitor for keys and a J110 for upright bass. Was thinking of just one wedge shaped J100 or a W10 to do both jobs, hence the comparison.DaveK wrote:Correct. That chart is the one for driver-only. No tweeters of any type.Bruce Weldy wrote:I'm assuming no piezos or horn on that J110?
For my own personal bass use, I am happy with my J110s in either one, two or three stacks for most my gigs which invariably have FOH so no I would not switch to a W10 for bass. I just need enough sound on stage and that's it. The T39/Dr250 are our FOH system. I am more concerned about what comes out of FOH than on stage and the T39/DR250 deliver excellent quality with heaps of low end if need be.
Here's an apples-to-apples comparison with a cab about the same size.
That looks like a tie to me. The J112 stacks better and takes a bit more power. The W10 has the flexibility to be used as either a wedge or a top. If I were looking at building a pair of J112's as tops, I'd seriously consider building W10's instead.
you guys must have all missed the thread where I was talking about using W10s as dedicated tops....
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
1x bastard XF208
- Drey Chennells
link it up mansine143 wrote:you guys must have all missed the thread where I was talking about using W10s as dedicated tops....
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
InfraCoustik
