amp for 4 tubas?
Is this amp OK?
pyroibw
amp for 4 tubas?
#1 Post by pyroibw »
hey. im about to finish up my build for 4 tuba 30's loaded with 3012lf drivers and was wondering what would be the best bang for buck amp to run them off of. any input is appreciated. thanks
Built: 8 T60's
Soon: * OT12's
SeisTres
Re: amp for 4 tubas?
#2 Post by SeisTres »
If you don't mind the weight, then the behringer ep2500 (also it seems the the new version [ep4000] seems to work just aswell). Also, the crown xls 802 sometimes can be had for a low price. But if I were you, I would check out some of the peavey ipr, or some of the new xls's since they start out pretty cheap. Now, if you still to go cheaper than all that, the only other option would be used gear, and for that, it's up to you to look around.
#3 Post by Chris_Allen »
Welcome to the forum, but where are you based?
pyroibw
#4 Post by pyroibw »
oh, forgot to add info. im in NY.
thanks for the info. i'll look into the ep2500, as i like and trust behringer. i'll look at the peveys to.
also, what power ratings am i looking for?
Built: 8 T60's
Soon: * OT12's
sine143
#5 Post by sine143 »
Do you want DSP or do you have and external crossover?
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
pyroibw
#6 Post by pyroibw »
i'll be running a external crossover
Built: 8 T60's
Soon: * OT12's
sine143
#7 Post by sine143 »
grab anything that will throw 800-1000 at 4 ohms. Maybe more if you want headroom, but you will be limiting them down a bit with your external xover/processor
1x bastard XF208
